Champion Accelerator Flush Valve
Discussion in 'Toilet Forum discussions' started by RBrown, Sep 11, 2007.
  1. RBrown
    RBrown New Member
    Sep 18, 2004
    West Virginia
    My sister's Champion toilet is having a flushing problem. American Standard sent her parts including a replacement for the "flush tower". It's call the Accelerator Flush Valve, and I hope it cures her problem. The new valve is similar to a flapper, except that it pulls straight up instead of being hinged. They also sent her a new tank gasket and a special plastic wrench.
    The AS website now touts the Accelerator Flush Valve, and the old flush tower is gone.
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Yes........and the trip lever doesn't work quite right unless the tank lid is pulled a little forward to where it lodges in a normal position.
    I switched one out about a week ago
    [​IMG]
    [​IMG]
    It's very hard to flush.....takes some strength to push that trip lever down. The second picture denotes that trip lever hanging almost
    vertical when the tank lid is off.
    Now there's almost 4" of unused water in the bottom of that tank as well. :confused:
  4. tonykarns
    tonykarns In the Trades
    Jun 5, 2007
    Interior Remodeling
    wisconsin
    Bad design
    To be honest with you thats about the worst design ive come across in a toilet! I just modified one about 3 months ago. I would at the least replace the bent up trip lever with a new one, attatch a second one with a degreed bend on it by using #10 ss small bolts so it extends over the release.
    This will at least make it easier to flush.
  5. RBrown
    RBrown New Member
    Sep 18, 2004
    West Virginia
    When you finished changing it out, did it flush ok? Does the trip lever point up all the time? I hope it doesn't, sis won't be too happy.
  6. Dunbar Plumbing
    Apr 18, 2005
    Yes........flushes okay but it's very hard to push that trip lever down to flush.
    The trip lever sits in a "normal" position when the tank lid is on...not off.
    I told the customer that if they have to have a plumber work on that toilet again......replace it completely and get away from that flawed design.
  7. Dunbar Plumbing
    Apr 18, 2005
    It seemed to me that it was the actual flush valve that was making it hard to flush....not the setup of the trip lever.
    I checked this by manually pulling the flush valve assembly up by hand.
    Lots of water/head holding that assembly down flat. I personally do not like the design at all.
  8. RBrown
    RBrown New Member
    Sep 18, 2004
    West Virginia
    Accelerator Flush Valve Installed
    Rugged,
    Sis got her toilet fixed today. Her plumber installed the AS Accelerator flush valve and it works fine. It's not too hard to push the trip lever, just a bit firmer than the AS Flush Tower. With the tank lid off, the trip lever is in its normal horizontal position, and the installation is neat as a pin. Her installation looks much neater than the pics you posted showing the arm all bent. She is a very happy girl. :)
  9. micp879
    micp879 New Member
    Jul 11, 2007
    Paramedic
    Martinez, CA
    Thanks for posting the results. I will be replacing the flush tower on my parents Champion toilet with the new accelerator valve in the near future, and I was getting a bit concerned, based on the posts in this thread. I was going to comment that in the above picture, the trip lever and trip lever arm look nothing like the trip lever in my parents Champion. The lever in theirs is longer and appears like it should be a much better match. It makes me wonder if a different trip lever would maybe benefit the toilet in the picture.
  10. Dunbar Plumbing
    Apr 18, 2005
    As I mentioned, that trip lever doesn't sit like that between flushes; it sits in a normal position due to the fact that the tank lid is holding it where a normal setting would be.
    There's a new trip lever ordered coming from A/S along with the fill valve they seemingly forgot to ship :mad: but I'm pretty sure that the homeowner won't put either on.......he'll most likely keep the items until either one fails. He won't be calling me back either to make a repair that's not malfunctioning either.
  11. steve_m_d
    steve_m_d New Member
    Jul 28, 2008
    Accelerator flush problems
    I had a problem getting the tower flush valve to flush. I had to hold the lever in just the right position to get it to flush before the valve dropped back down. So, I just replaced the tower with the newer designed Accelerator, and it is worse! I have to hold the lever down until it flushes, or else it won't flush. Is there some kind of adjustment? What is the mechanism which should hold the "flapper" up until there is a flush?
    I am thinking of cutting my losses and getting a whole new toilet.
  12. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Steve I would consider that to be a very wise choice... They are now having problems with blisters forming on the replacement flappers as well. You can read about it in the Champion thread 250 plus posts from happy owners... Yea that'll be the day!
    May I suggest a Toto?
  13. steve_m_d
    Jul 28, 2008
    Thanks for the recommendation. I looked at Eljer and Kohler at Lowes and Home Depot, but they don't seem to be getting very good user reviews.
  14. Redwood
    Dec 15, 2007
    Service Plumber
  15. maddog
    maddog Engineer
    Aug 1, 2006
    Software Engineer
    near San Jose, CA.
    Steve. I also put in the new Champion flush valve and have not had any problems. It's not hard to flush and it actually flushes great. Note that the flush arm is pretty much straight over the flush valve and that there is just a little bit of slack in the chain. Also, I set the water height to about a half inch below the top of the refill tube. Good luck. -dog.
  16. steve_m_d
    Jul 28, 2008
    Thanks, Maddog.
    Maybe the flush valve wasn't my real problem. I went ahead and replaced the toilet with the Toto Drake. The new toilet flushes, but doesn't seem to have any power. Anyone know if there is some sort of adjustment I can try? The tank seems to be filling fine.
  17. Redwood
    Dec 15, 2007
    Service Plumber
    Steve while the flush seems very different trust me the power is there. It will take anything you give it!
  18. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Steve, you have one of the finest toilets made, and it is working fine so don't try to adjust anything. You are just used to an old full flow monster that dumped 4 or 5 gallons of water so it's hard to believe that 1.6 gallons can be effective, but it is.
  19. maddog
    maddog Engineer
    Aug 1, 2006
    Software Engineer
    near San Jose, CA.
    Not sure you can compare the flush to that of the Champion. The Champion has a very 'violent' flush - probably to get all those golf balls down! Don't think you can go wrong with the Drake, though. I'll probably be looking at the Eco-Drake if this new flush valve doesn't work out. There was a post from one user that the new flush valve seal began leaking after about 4 months.
    I'm a little concerned about what the tile floor might look like with a different bowl foot-print. The tile guy put grout around the base. It looks real nice, but could be difficult to get completely off. Good luck with the Drake! -dog
  20. tntrvlngrl
    tntrvlngrl New Member
    Feb 8, 2013
    Tennessee
    Flush valve
    I've had this flush valve for about 4 or 5 years and I love it; it works perfectly!
Similar Threads: Champion Accelerator
Toilet Forum discussions American Standard Champion 4 Mystery Part Jan 5, 2017
Toilet Forum discussions Toto Eco Drake vs Kohler Wellworth vs AS Champion Pro Jan 1, 2017
Toilet Forum discussions Champion Max 4 - Fill Valve Issue Dec 21, 2016
Toilet Forum discussions Toto Drake 1.6 vs Toto Drake 1.28 vs. Toto Entrada (vs. AS Champion 4 max?) Aug 19, 2016
Toilet Forum discussions Identifying and replacing broken cylindrical American Standard Champion flush valve,. Apr 21, 2016
