Ceramics and Durock
Discussion in 'Shower & Bathtub Forum & Blog' started by Buster55, Jan 5, 2007.
  1. Buster55
    Buster55 New Member
    Jan 5, 2007
    Hello all,
    Brand new to your forum and renovations are happening as I type. Can anyone tell me do I put ceramic tiles on the smooth side or the rough side of durock? (I have read that when using mortar the ceramic tiles should be affixed to the rough side, this is a first for us so we are looking for some friendly advice...T I A
  2. Cal
    Cal New Member
    May 10, 2005
    Northern Virginia
    Mortar & The rough side .
  4. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    both will work
    although the rough side is better since it gives more roughness for the glue or cement to cling to.
    if this is for a wet wall, use no mastic (organic glue) know as tile cement.
    david
  5. Buster55
    Buster55 New Member
    Jan 5, 2007
    Thanks Cal!!
  6. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    I only use mastic when attaching ceramic tile to wood.
  7. Cal
    Cal New Member
    May 10, 2005
    Northern Virginia
    Randy ,
    WHY ?? Mortar is SO much better ! Mastic is the cheap-man's way.
    You can get pre-mixed mortar and it's still better then mastic .
    Maybe I'm wrong ,,,,, Maybe brick layers should start using mastic ,,,it's faster
  8. geniescience
    Nov 27, 2005
    ditto
    pre-mixed isn't Portland. Is it mortar?
    terms are not always the same everywhere. Words not "protected" can be taken over by new prodcuts that claim to be just like the older products.
    hope someone can help explain how a substance can be pre-mixed and still be a cement mortar. If anythign sticky can be called mortar, then i take back what i said above about martar, and i now say cement mortar, or Portland cemetn mortar.
    to me, anything pre-mixed is not a cement mortar. That is a mastic, to me.
    So, my remarks above apply to all pre-mixed substances that stick tiles. They aren't the best choices for wet walls. Moisture and pre-mixed don't perform well together.
    david
  9. Randyj
    Nov 25, 2006
    Alabama
    I've used mastic because (a) the customer bought it and wanted me to use it. (b) walls in kitchens and non-moisture areas are more suitable for use of the "glue" where there is questions about mortar sticking to the surface. On a weight bearing surface there is only one way to go...CBU with mortar if there is not a concrete base. Mastic also is good where you want to avoid dust and alot of clean up.
  10. geniescience
    Nov 27, 2005
    ditto
    good for a lot of applications
    but not where the walls will be wet.
  11. Randyj
    Nov 25, 2006
    Alabama
    yep.. that's what i've been tolded
Similar Threads: Ceramics Durock
Shower & Bathtub Forum & Blog New tub, Do I Durock over lip? Is it OK to use PVC W&O drain? Nov 9, 2016
Shower & Bathtub Forum & Blog Durock Board without tiles in bathtub Nov 9, 2015
Shower & Bathtub Forum & Blog CGC Durock Shower System - Review Oct 17, 2013
Shower & Bathtub Forum & Blog Preparing durock for spray- on texture Jun 17, 2013
Shower & Bathtub Forum & Blog Which is better for shower surround? Durock or Hardibacker? Jul 23, 2010
