centrifugal start/run switch not engaging
keeny
changed out the start capacitor matched to a 1/2 hp pump.....it kicks in now and then but within a day gets hung up, over heats and shuts down......I can manually turn the shaft a bit, give it power and it runs till it hangs up again
DonL
Houston, TX
You should be able to lube the Weights. And make sure the points aren't pitted.
That will work if the motor is up to speed.
Good Luck.
