Cement Lined Water heater?
Discussion in 'Water Heater Forum, Tanks' started by TMP>9a59, Dec 11, 2011.
  1. TMP>9a59
    TMP>9a59 New Member
    Dec 11, 2011
    Florida
    Just starting the research phase of a new water heater for the house. I see there is a company named Hubbell that makes a cement lined water heater instead of glass lined. Their Model E is a light commercial duty, so for a home it would be more than adequate (if sized correctly). I know it would be heavier, but the location is on a concrete slab with good access.
    Other than costing more, is there any real differences (advantages) to a so called "stone lined" water heater? Does it interact with softened water in a detrimental way?
    I have found a few conversations where these types of heaters have a life span of 20 plus years.
    Thanks
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    What would be the heat source? Sure, the tank could last longer but it could fill up with lime scale and affect the heat transfer. I know that I would not want a gas water heater to last 20 plus years as the efficiency would be way off with no easy way to clean it.
  4. ballvalve
    Dec 28, 2009
    northfork, california
    I have only seen cement lined electric heaters, as they are spun coated, not possible with a central tube.
    I was cutting a 30 year old one up for a trough, when I learned of their existence - couldnt quite figure why it was so heavy. No torch can cut a cement lined tank. Scrapped it, and made a bunch because they dont look inside.
    I would go with it, but you need good access to move it.
  5. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Years ago tanks that were used to store hot water that was produced from various sources were stone lined. Many were 80 and 120 gal. I can still see them sitting horizontally on pipe stands 2'-3' off the floor. I'm sure hj also remembers them. They also were covered with asbestos.
    John
  6. ballvalve
    Dec 28, 2009
    This one had a georgeous copper finned heat exchanger in a set of ports which I did manage to cut out. No Asbestos. Likely a solar tank.
  7. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    When I did a quick google search I was finding steam heated units but have since found the electric model E the OP mentioned.
    http://www.hubbellheaters.com/html/modele.htm
  8. ballvalve
    Dec 28, 2009
    I had another one that I welded a patch on over a leak in my poor youth, and the damn thing lasted another 15 years. "curbside pickup" built my first house.
    What I fancy is building a house with those huge bales of compressed cardboard boxes. Probably win every enviro award in the nation.
Similar Threads: Cement Lined
Water Heater Forum, Tanks 20 year old natural gas HWH replacement options Feb 21, 2017
Water Heater Forum, Tanks Gas water heater replacement recommendations Dec 3, 2016
Water Heater Forum, Tanks Water Heater Replacement Help - Picture Attached Jan 4, 2016
Water Heater Forum, Tanks Water heater replacement in modular home Dec 26, 2015
Water Heater Forum, Tanks Would like recommendations for indirect replacement Oct 26, 2015
