Cement cure time?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by djqfr, Jun 10, 2007.
  1. djqfr
    djqfr New Member
    Jun 7, 2007
    How long does it take for ABS cement to cure? I put in drain pipes on Thurs/Fri and I can still smell something strong in the bathroom. It doesn't smell like sewer gas (no rotten egg smell.)
    It hasn't been all that warm here (13C-17C) and I figured that smell should be gone by now...
    Edit: I should add all I have for ventilation is the bathroom fan. I closed the bathroom door hoping the fan would suck the air out, but after a while I thought that fresh air can't get in then. ;)
  2. jadnashua
    The solvents in the cement are pretty strong, and depending on how much you put on, can linger for awhile. It probably helps if you are using the drain , too. that may wash away any surface stuff. Never used ABS, only PVC, but that can linger, too. If there is a trap, have you run water down the thing enough to fill the trap?
  4. djqfr
    djqfr New Member
    Jun 7, 2007
    Yeah, I put water down to fill the trap.
    It's a pretty strong smell, and the problem is compounded by only having a bathroom fan and not a window.
    What clued me in on the smell is (of course) I got cement all over my hands and the smell was the same. The instructions on the cement can said use lots, so I did...
Similar Threads: Cement cure
Plumbing Forum, Professional & DIY Advice Cast iron tub ledger board placement Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Moen Chateau knob replacement ? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice P Trap replacement Feb 5, 2017
Plumbing Forum, Professional & DIY Advice Tub-Shower Valve Stem ID/Removal/Replacement Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Replacement Handle for American Standard Tub/Shower Jan 17, 2017
