Ceiling fan running slow
Discussion in 'Electrical Forum discussion & Blog' started by blah204, Jun 20, 2010.
  1. blah204
    blah204 New Member
    Jun 19, 2010
    North Carolina
    I need a little understanding why my ceiling fan is running SO slow, PLEASE! I have a ceiling fan with lights attached to it. The lights are are on a seperate switch and that switch is a slide dimmer switch. The fan is on a regular 120 switch. When the fan starts up it starts slow and steadily gets to its max speed. It does have 3 different speeds. Each speed is different, but still extremely slow (50, 100, 150 RPM respectively) estimate of course, but not far of. I'm just trying to understand what it could be. It has done this ever since we got it. I'm pretty sure its wired correctly. I don't know how it couldn't be. Wouldn't it not work at all if it was miswired? Meaning the lights wouldn't work, the speeds wouldn't change? Thanks
  2. Ford2001
    Ford2001 New Member
    Sep 11, 2009
    property care taker
    Manchester, Vermont
    You don't use slide dimmer for ceiling/paddle fans, their used for lighting. Buy a control that made for ceiling/paddle fan. Ask a store clerk for help.
  4. blah204
    blah204 New Member
    Jun 19, 2010
    North Carolina
    The slide dimmer is for the lights. The fan and lights are seperate from each other. They use different switches. If I'm not mistaken, the only thing they share is a neutral and GND. One thing I found was that the Start/Run Capacitor could be causing this. My only problem is, wouldn't that effect all 3 speeds. Meaning, wouldn't all 3 speeds run the same.
  5. Ford2001
    Ford2001 New Member
    Sep 11, 2009
    property care taker
    Manchester, Vermont
    Blah 204, I read your post wrong. Did you run a three wire cable to the ceiling fan with light kit. That goes, black, red, white, bare copper ground. Are you sure the dimmer which control's the ceiling fan light kit, is wired to the correct wire, that feed the lights. It easy to get cross. Suggestion: I would double check my circuit wiring first. Then I would removed the slide dimmer and replace with on/off toggle switch. If the 3-speed fan, with its pull chain doesn't operate correctly, then take back to the store you purchase it from for a new. Good Luck,
Similar Threads: Ceiling running
Electrical Forum discussion & Blog Need help wiring ceiling fan! Wednesday at 6:14 PM
Electrical Forum discussion & Blog Recessed light in fire rated ceiling? Nov 16, 2016
Electrical Forum discussion & Blog Question about Ceiling Fan wiring Nov 9, 2016
Electrical Forum discussion & Blog Ceiling Fan & LED Lighting Sep 1, 2016
Electrical Forum discussion & Blog Drop Ceiling 2x4 LED options Oct 24, 2015
