Ceiling Fan Issue - Humming Sound When Light Off
Discussion in 'Electrical Forum discussion & Blog' started by MK_Chicago, May 20, 2014.
  1. MK_Chicago
    MK_Chicago New Member
    Nov 23, 2013
    Illinois
    Hi Everyone,
    I recently installed a new Hunter ceiling light/fan combination to replace an old fan and am trying to troubleshoot an issue. When the fan is running AND the light is on, the fan works perfectly and is quiet. However, when I turn the LIGHT off and keep the fan on, the fan starts to make a metallic sound. It is consistent and almost sounds like a rubbing sound. If it happened all the time, I'd think something inside the fan was rubbing. However, it ONLY happens when the light is off. When I turn the light back on, it stops/
    I thought maybe it had something to do with the dimmer I had so I replaced it with a new dimmer and then tried a standard two switches (no dimmer). Nothing resolved the issue. I also did not have this issue with the previous fan.
    Any ideas? Is it a problem with the fan? Problem with the connections I made?
    These are the connections I made:
    From Fan to Ceiling:
    BLUE to YELLOW
    BLACK to YELLOW
    WHITE to WHITE
    Green/Yellow to GREEN
    I also labeled the yellow wires so I knew which were attached to Blue and which to Black on the old fan.
  2. hj
    My initial reaction is that you have something miswired, possibly in series, and the fan does not get full voltage until the light is turned on.
  4. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    What is your Black(Hot) connected to ? It seems to be missing.
    The 2 Yellow wires go to your dimmer ?
    What is the model of your fan ?
    Good Luck.
Similar Threads: Ceiling Issue
Electrical Forum discussion & Blog Need help wiring ceiling fan! Feb 15, 2017
Electrical Forum discussion & Blog Recessed light in fire rated ceiling? Nov 16, 2016
Electrical Forum discussion & Blog Question about Ceiling Fan wiring Nov 9, 2016
Electrical Forum discussion & Blog Ceiling Fan & LED Lighting Sep 1, 2016
Electrical Forum discussion & Blog Drop Ceiling 2x4 LED options Oct 24, 2015
