cbu subfloor under shower base?
Discussion in 'Shower & Bathtub Forum & Blog' started by Tobias, Apr 14, 2007.
  1. Tobias
    Tobias New Member
    Apr 14, 2007
    I’m redoing a small bathroom that has not seen any TLC in 45 years. I now ready to install a new Swanstone neo-angle shower base; just not sure what the best way to do this is.
    The subfloor is 3/4" t&g board. It’s in good condition, just not perfectly level.
    Option 1: I put 15lb felt and metal lath on the subfloor and install the base in mud.
    Option 2: I put cement backer board on the entire bath room floor, add two coats of Redgard and install the shower base directly onto the cbu - nested in mud for stability. That seems to be easier and faster but is cbu OK under the shower base?
    Which way would be best? I would like that bathroom to last for the rest of my life, so “overkill†is just fine :)
    Thanks,
    Tobias
  2. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    i wouldn't do option #2, but i would first get Swanstone to say what they require in terms of strength under the neo-angle base, like for example L = 1/360 deflection in floor, or how much?
    david
  4. jadnashua
    Deck mud should be probably thicker than you want. How out of level is it? A medium bed thinset can be installed up to about 1/2" or maybe more depending on the brand - no lath required.
  5. Tobias
    Tobias New Member
    Apr 14, 2007
    well, I went with 15lb felt, metal lath and a bag of mason mix. nearly forgot to cut a hole for the drain in the lath ;-)
    shower base is level and rock-solid.
    Tobias
  6. jadnashua
    that should work! The main goal is to prevent the fiberglass or whatever system from flexing when walking around in the shower. Fully supporting it both makes it feel much more substantial and prolongs its life by preventing stress cracks. A secondary, but necessary function is it gives you the opportunity to level the shower floor, which is very important for proper draining and trying to make the walls look good.
Similar Threads: subfloor under
Shower & Bathtub Forum & Blog Rotted subfloor under cast iron tub, considering my options. Oct 10, 2016
Shower & Bathtub Forum & Blog What height to install my niche relative to my subfloor? Jul 18, 2016
Shower & Bathtub Forum & Blog Flange & subfloor question Nov 8, 2015
Shower & Bathtub Forum & Blog Moving a shower drain on plywood/mud subfloor Feb 26, 2015
Shower & Bathtub Forum & Blog proposed subfloor removal for bathroom remodel Dec 15, 2014
