CB trips on water heater
Discussion in 'Water Heater Forum, Tanks' started by Andrew1964, Aug 21, 2012.
  1. Andrew1964
    Andrew1964 New Member
    Aug 21, 2012
    UK
    I have a double pole switch for the hot water emerssion heater, when I switch on the water (bath or sink) the CB breaker trips.
    At first this only happened when I put on bath but now it happens on both.
    When I disconect the wires from the element on the tank, the CB does not trip and I have power in the wires to the element.
    Do I need to change the elment or the thermostat?
    Do I need to drain the tank to do so, the element is at the top of the tank.
    Thank in advance
    Andrew1964
Similar Threads: trips water
Water Heater Forum, Tanks New Electric Hot Water Heater Trips Breaker Jun 26, 2011
Water Heater Forum, Tanks Hot Water Heater High Limit Switch Continualy Trips Apr 18, 2010
Water Heater Forum, Tanks Hot water braker trips once in few weeks Mar 25, 2010
Water Heater Forum, Tanks My T&P valve is expelling 1 cup of water per day Today at 11:17 AM
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Wednesday at 10:49 AM
