Caulking for shower
Discussion in 'Shower & Bathtub Forum & Blog' started by white tiger, Oct 20, 2009.
  1. white tiger
    white tiger New Member
    Feb 20, 2005
    We have an apartment that we installed a new tub and surround, anyway the surround did not fit perfectly tight around the tub and there were some gaps that needed to be caulked. About every six months we have to reseal it from the water that the shower sprinkles on it when taking a shower. My question is what is the best product to use for sealing around the tub that will not have to constantly be redone? Thank you for your time!
  2. Cass
    Cass Plumber
    Nov 12, 2005
    What are you using now?
  4. white tiger
    Feb 20, 2005
    A silicone caulking. I dont remember the name.
  5. jadnashua
    How big is the gap? No caulk is designed to bridge large gaps. Sometimes a foam backer rod is called for as well. Also, the tub may move when filled with water or someone stands in it, so it is often a good idea to caulk while the tub is full so the seal isn't stressed (stretched) as much when it is occupied. compression is easier on the seal.
  6. white tiger
    Feb 20, 2005
    Up to a quarter in in spots. Where can a foam backer rod be purchased?
  7. jadnashua
    You can probably find it at a good local home center, but you may need to look online. This link has some good info on caulking. They also explain why a backer rod helps. The company also sells a mildew free caulk. If installed properly, and you get mildew within 7-years, they'll pay a contractor to redo it. Now, what you have to do to verify it was installed properly in the first place, I did not look up. I have no association with this company and haven't used their products. But, the info on caulking is good and is based on industry standards. http://www.sashcosealants.com/Home_Improvement/Caulking_101.aspx
  8. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    1/4" gap in tub deck
    A 1/4" gap is huge. Does the measurement change when you fill the tub with water?
    The rule of thumb for chaulking or grouting is that you want to have at the least the same depth of chaulk installed as the width. When running your chaulking along the seams you have to slow down and fill the voids to get the extra material in there.
    Remove the old material and clean with rubbing alcohol and silicone the next day.
  9. jadnashua
    You don't want a real deep, slug of caulk, it is more flexible and less prone to failure if the ratio is more like 2:1 (if you believe the linked article). The backer rod helps in this and shaping it for best effect.
Similar Threads: Caulking shower
Shower & Bathtub Forum & Blog Help, shower leaking around tile and caulking gap Dec 26, 2015
Shower & Bathtub Forum & Blog Leak under base of corner shower stall doors after cleaning, re-setting and caulking Mar 30, 2013
Shower & Bathtub Forum & Blog shower stall keeps leaking despite re-caulking everything Oct 2, 2012
Shower & Bathtub Forum & Blog Caulking a 2-piece acrylic tub shower Feb 22, 2011
Shower & Bathtub Forum & Blog Best caulking for acrylic shower base Sep 26, 2010
