Caulking behind Three Piece Mirolin Shower
Discussion in 'Shower & Bathtub Forum & Blog' started by mdpitt, Aug 16, 2008.
  1. mdpitt
    mdpitt New Member
    Aug 16, 2008
    I recently installed a Three Piece Acrylic Mirolin Shower, part of the instructions said to caulk behind the unit were the pieces join, as this is a retro fit into an existing house how would anyone do that and is it 100% necessary, of course I don't want moisture behind the unit and putting caulking on the facing side sort of takes the look and appeal aware from having this type of unit, however, will my bathroom fan (120cfm) be enough to pull that moist air out of the room, thoughts?
  2. hj
    caulk
    Do the pieces overlap? If so put the caulk on the back side of the overlap. Even in a new house you could not get behind it if it were next to an outside wall. What does the fan have to do with keeping the shower from leaking, which is the purpose of the caulk.
  4. mdpitt
    mdpitt New Member
    Aug 16, 2008
    Yes the piece overlaps about 3 inches, I was thinking the pupose of the caulking was to make a vapor barior between the unit and walls behind it, I not sure if the caulking is realy nessesatry? (thanks for replying so quickly)
  5. mdpitt
    mdpitt New Member
    Aug 16, 2008
    Oh, Also I mentioned the fan so that that elps suck moister out of the bathroom, I guess my concern is will moist air get under the overlaps and cause problems?
  6. hj
    enclosure
    Your concern MUST be that water doesn't get through the seam and damage the building. It has nothing to do with humidity.
Similar Threads: Caulking behind
Shower & Bathtub Forum & Blog tub caulking won't dry. Slow leak behind wall? Jul 16, 2007
Shower & Bathtub Forum & Blog Caulking around trim sleeve? Yesterday at 3:08 PM
Shower & Bathtub Forum & Blog Help, shower leaking around tile and caulking gap Dec 26, 2015
Shower & Bathtub Forum & Blog Is caulking necessary? Jun 16, 2013
Shower & Bathtub Forum & Blog Leak under base of corner shower stall doors after cleaning, re-setting and caulking Mar 30, 2013
