Caulk: Silicone,Polyseamseal, Hercules or Other?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by molo, Jul 23, 2011.
  1. molo
    molo Member
    Sep 23, 2006
    Cold New York
    Tub surrounds, what is the best caulk for the gap between a plastic surround and the tub?
  2. Will Rogers Plumbing
    Will Rogers Plumbing Plumbing Contractor
    Oct 8, 2010
    Plumbing Contractor
    Moore, Ok
    You talking tile or cultured marble? Tile you will want to use color match caulking(it will be sanded like the grout) and for cultured marble (or any solid surround) you will want to use silicone.
  4. plumber2011
    plumber2011 Expert Plumber
    Jun 4, 2011
    Licensed master plumber and owner of small residen
    Boston, Massachusetts
    Hi Molo
    Liquid nails sells a specific TUB SURROUND CAULKING...see image. This will definitely be the best bet for plastic surround panels as you can be sure the caulking won't bleed through the plastic panel as some other caulking can. It should be available at any home depot or lowes store.
    In terms of the "GAP" between the tub and the plastic surround, I'd recommend 1 or 3 hour shower caulking by GE (see image)....fast drying and mildew resistant guaranteed for 10 years...also available at any home depot or lowes.
    Good luck!~
Similar Threads: Caulk SiliconePolyseamseal
Plumbing Forum, Professional & DIY Advice Removing hardened caulk from behind pedestal sink/tiled wall Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Removing caulk stain on granite Aug 4, 2016
Plumbing Forum, Professional & DIY Advice Oatey No Caulk Brass Shower Drain Jan 29, 2016
Plumbing Forum, Professional & DIY Advice Shower Drain For Fiberglass Shower - Caulk Or No-Caulk Design - Do Or Don't Do? Dec 11, 2015
Plumbing Forum, Professional & DIY Advice Hole in exterior wall where HVAC condensation line comes in. Seal with caulk? Jun 25, 2015
