Catch basin question in chicago
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by TD1974, Sep 13, 2008.
  1. TD1974
    TD1974 New Member
    Sep 13, 2008
    I cut off my gutters (they are draining above ground) and have all new sewer system that is overhead and runs out to the street. I assumed this would take care of any water running into the catch basin. However during a heavy rain, the catch basin has filled with water. Where would it be coming from? PLease note non of the house plumbing is tied to the catch basin. Also the reason for the questions is that the catch basin is located in a crawl space.
  2. drick
    drick In the Trades
    May 16, 2008
    I assume by catch basin you mean sump pump pit. You probably have perimeter drains around the interior of your basement/crawl space foundation that drain into it. This is fine. Its also possible that you have exterior perimeter drains around the foundation that drain into it. This is generally a bad design as you don't want to bring storm water into the house but its been done before. If your sure gutters were tied into this than there is a reasonable possibility that the exterior perimeter drains are also draining into this. Not ideal but at this stage the easiest thing to do is install a pump and live with it. Redoing perimeter foundation drains is A LOT of work (I've done it - not fun), expensive, messy and not worth even considering unless you have serious basement water issues.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I believe that the poster means something like this...
  5. hj
    catch basin
    In Chicago a "catch basin" usually means a grease trap for the kitchen sink. ALL homes used to have them although I do not know if they are still a requirement.
  6. TD1974
    TD1974 New Member
    Sep 13, 2008
    I have simp pit. The house I own is over 90 years old. The old catch basin was for the gutters and the kitchen grease. I have no plumbng from my home going to it. I totally remodeled the house. But during heavy rains it fills with water. I can see to pipes coming to it and both drain a little water into it. Cant figure out where they are coming from.
    Any thoughts?
Similar Threads: Catch basin
Plumbing Forum, Professional & DIY Advice trap for floor drain catch basin Apr 26, 2012
Plumbing Forum, Professional & DIY Advice Catch Basin / Exterior Gutter Downspout Tiles Smell Feb 11, 2006
Plumbing Forum, Professional & DIY Advice Leaky Galvinized Kitchen Drain / replace and skip catch basin? Oct 12, 2005
Plumbing Forum, Professional & DIY Advice Capped off drain50 gal. On w.h. ??????? I catch you i kill you Aug 20, 2012
Plumbing Forum, Professional & DIY Advice Knew They Would Catch Some of Ya'll Feb 27, 2012
