cast iron under the sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by prt6709, Apr 22, 2007.
  1. prt6709
    prt6709 New Member
    Apr 22, 2007
    I have a 50 yr old house. I am replacing the sink. Under the counter is cast iron pipes coming into the house, iron j-trap and then connects to pvc to connect to the sink. This comes out to 14" from the wall. The new sink I bought, the holes are only 7" from the edge of the sink. There is a cast iron coupling right at the wall where the iron comes in and a 9" pipe between the wall and the iron j-trap. How can I shorten this to 7 or 8"? I don't do much plumbing. Is there a special tool to work with removing cast iron pipes? Or is it worth it? I'm thinking about just getting a different sink.
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    I usually cracked those (Durham), cast fittings, with a heavy short handled sledge and backed it up with an 18" pipe wrench. Or you can cut the steel pipe back near the wall and give yourself more room and transition with a no-hub band to pvc.
Similar Threads: cast iron
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Tuesday at 1:12 PM
Plumbing Forum, Professional & DIY Advice Cast iron sewer problems. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron tub ledger board placement Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron riser to toilet flange Feb 5, 2017
Plumbing Forum, Professional & DIY Advice 1950s cast iron sewer line clogged Jan 28, 2017
