Cast Iron Tub Install
Discussion in 'Shower & Bathtub Forum & Blog' started by Iree, Oct 26, 2009.
  1. Iree
    Iree New Member
    Oct 26, 2009
    North East
    Installing a Kohler 300 lb cast iron tub and I know my bathroom floor is slightly off level. Is it ok to just lay 1/2" hardibacker on the entire floor, then poor leveler down - whole room, let it dry and then set the tub on a level floor. I would then tile up to the tub apron.
    Most online forums say install the tub on wood subfloor, then level it with shims but I am concern over time the wood subfloor may deteriorate. Also, with 1/2" hardibacker plus leveler, then and about 3/8" or so tile thickness - I am up to about an inch or more the side of the apron... .
    Interested in your thoughts/advice
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    What kind of shape is the sub flooring in? In new homes we set the tub on the sub floor. They were also Kohler CI tubs.
    John
  4. Iree
    Iree New Member
    Oct 26, 2009
    North East
    I ripped out particle board and installed 3/4" pressure treated plywood over the 1/2" on so it is new.
  5. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    That should be fine. Just shim the tub as needed.
    John
Similar Threads: Cast Iron
Shower & Bathtub Forum & Blog Cast iron drain...can I avoid the jackhammer? Jan 13, 2017
Shower & Bathtub Forum & Blog Cast Iron Tub Install - 5 x 8 Bathroom Oct 11, 2016
Shower & Bathtub Forum & Blog Rotted subfloor under cast iron tub, considering my options. Oct 10, 2016
Shower & Bathtub Forum & Blog Demo a cast iron tub with a sledge hammer. Aug 20, 2016
Shower & Bathtub Forum & Blog Installation Cost For Cast Iron Tub Vs. Acrylic May 4, 2016
