Cast Iron Shower Drain Disintegrated
Discussion in 'Shower & Bathtub Forum & Blog' started by ChrisJG, Jan 24, 2010.
  1. ChrisJG
    ChrisJG New Member
    Jan 24, 2010
    Los Angeles, CA
    I'm remodeling my bathroom. When I removed the shower pan, the drain pipe rusted off. Sand fell into the drain pipe. I can probably vacuum out. See attached picture . I have concrete slab foundation. Not sure what direction I should take on this. Should dig deeper to expose more of the pipe and repair? Or call a professional?
    Thanks,
    Chris
  2. hj
    I have absolutely NO IDEA what the picture is showing, but at this point I think a professional is the best choice.
  4. ChrisJG
    ChrisJG New Member
    Jan 24, 2010
    Los Angeles, CA
    Sorry. Should have had a better picture. The picture shows what use to be the shower drain. The pipe was so corroded that the drain broke off when I removed the shower pan. What is sticking out of the sand is the drain. A little sand fell into the drain. Is there a way to repair myself? Can I do it without breaking up foundation.
  5. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    VA
    I think the problem is that if the riser was in that bad of shape, the p-trap and further down may be bad too. Assuming the rest of the piping was okay, I would make the hole larger, dig down the the p-trap and replace the p-trapand riser with ABS or PVC. Then use a proper Fernco coupler to connect the plastic to the cast iron.
    Since you don't know the condition of the rest of the plumbing, I would get a pro to come and take a look at it and see what he thinks.
Similar Threads: Cast Iron
Shower & Bathtub Forum & Blog Cast iron drain...can I avoid the jackhammer? Jan 13, 2017
Shower & Bathtub Forum & Blog Cast Iron Tub Install - 5 x 8 Bathroom Oct 11, 2016
Shower & Bathtub Forum & Blog Rotted subfloor under cast iron tub, considering my options. Oct 10, 2016
Shower & Bathtub Forum & Blog Demo a cast iron tub with a sledge hammer. Aug 20, 2016
Shower & Bathtub Forum & Blog Installation Cost For Cast Iron Tub Vs. Acrylic May 4, 2016
