cast iron radiator
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Eagle71, Oct 27, 2013.
  1. Eagle71
    Eagle71 New Member
    Aug 15, 2012
    Nj
    Hello all. I need to remove a cast iron radiator next month for a bath remodel. I've done this many times but not during cold weather when the system needs to be on during renovations. I initially thought I could take out the radiator and plug the unions, but apparently there are differing opinions on this. I read that some people plug and others put a jumper pipe in between the two. I don't see the problem with plugging the supply and return since closing the valve somewhat does this anyway. What to do? thanks
  2. hj
    If the radiator has a valve, then you have a "main pipe" system and you can cap the risers. IT is when you have a "continuous" loop that a jumper has to be installed, but that type of system does not have individual valves.
  4. Eagle71
    Eagle71 New Member
    Aug 15, 2012
    Nj
    Thanks man. That's what i thought. Just wanted to be sure.
  5. Eagle71
    Eagle71 New Member
    Aug 15, 2012
    Nj
    I removed the rad yesterday and capped off both copper lines. Then refilled and bled system. Just curious though, now that there is some air trapped in those two capped pipes will it adversely affect the system?
  6. jadnashua
    IF you've got flow everywhere, the air in there will eventually be absorbed into the water and purged out, but that could take months. I doubt there is enough volume in those pipes to affect the water pressure much, or enough trapped oxygen to be much of an issue. I'd monitor the pressure over the first couple of weeks, but you'll probably not notice...depends on how the expansion tank is setup whether the volume change would make any difference...probably not.
Similar Threads: cast iron
Plumbing Forum, Professional & DIY Advice Hard buildup in cast iron drain pipe Mar 18, 2017
Plumbing Forum, Professional & DIY Advice How do I tell if the Soil Pipe is Cast Iron or Steel? Mar 17, 2017
Plumbing Forum, Professional & DIY Advice PVC to Cast Iron for toilet drain Mar 12, 2017
Plumbing Forum, Professional & DIY Advice Chinese cast iron no hub vs Charlotte Mar 11, 2017
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Feb 21, 2017
