Cast Iron Question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Smunderdog, Oct 17, 2009.
  1. Smunderdog
    Smunderdog New Member
    Apr 5, 2009
    Indiana
    I have a 1957 ranch with what I believe to be the original cast iron drain lines. When this was put in, why would they have used 4" pipe run vertically down from the toilets (only about 18" or so), then transitioned to 3" using a 4 x 3 elbow, then run the 3" to the 4" main line?
    Why wouldn't they have just run 3" all the way from the toilet to the main and then transitioned to 4"?
    Just curious more than anything...
  2. jimbo
    jimbo Plumber
    Hard to say what they were thinking, but to the best of my knowledge, it would never have beeen legal under any code to transition a waste line to a smaller size.
    If this has been working since 1957 without problems, I would be the last one to recommend you go out and change it.
  4. Smunderdog
    Apr 5, 2009
    Indiana
    Thanks Jimbo - that is what I thought. Has been working most likely because the vertical 4" run is only 18" or so and then the horizontal 3" run is only another 18" before it hits the 4" main. At least it is that way on the one I'm redoing in the near future...
    As part of my project of replacing a good portion of my cast drain lines, I'll be replacing the toilet drain with 3" for the entire run between the toilet to the main...
  5. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    This is just information: It was a common practice to use a 4x3in closet bend with the cast iron systems. It is still legal under the UPC, the only place that you can do that, that closet bend is also close to a true 90deg. fitting. :)
  6. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Give Shacko a cigar :D Closet bends can be 4" under both the UPC and the IPC And it was very common because it's darn near impossible to find a 3" CI toilet flange.
  7. jimbo
    jimbo Plumber
    But does anyone maintain that code allowed you to run a few feet of four inch pipe, then transition that to 3" pipe? I am not arguing that it works...he has told us that.
  8. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I think that's one of dem gray areas.
  9. hj
    4x3 bend
    It not only works, but it is legal, and is the only way I have ever done it, other than when we were using all 4", then we used 4x4 closet bends. Plumbers who use 3" toilet risers, in my opinion, are more concerned about how inexpensively they can install it, rather than what is best for the customer.
Similar Threads: Cast Iron
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Tuesday at 1:12 PM
Plumbing Forum, Professional & DIY Advice Cast iron sewer problems. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron tub ledger board placement Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron riser to toilet flange Feb 5, 2017
Plumbing Forum, Professional & DIY Advice 1950s cast iron sewer line clogged Jan 28, 2017
