Cast Iron Pipe?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by waggscreek, Feb 6, 2008.
  1. waggscreek
    waggscreek New Member
    Feb 6, 2008
    Mom
    Seattle
    I am moving a drain pipe that used to be connected to a bathtub (I'm building a shower.) The drain pipe is cast iron and I need to connect plastic pipe to it. Can anyone tell me how I can do this?
  2. Terry
    Aug 17, 2004
    It's a little tough to tell from the pictues,
    You may have a hub there, that will take a pipe using a rubber fernco inside hub seal.
    This is how plastic would look into the hub.
    [​IMG]
  4. waggscreek
    Feb 6, 2008
    Mom
    Seattle
    Thank you, I"ll go check.
    Susan
  5. Garrett
    Garrett In the Trades
    Feb 5, 2008
    Georgia
    looks like a lead stub but I cant see if thats cast its connected too.
  6. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    I hope that wasn't a load bearing toothpick in the picture, Terry!
  7. waggscreek
    Feb 6, 2008
    Mom
    Seattle
    Here are the picures of the pipe. I believe it is all cast iron? I would be able to hammer a dent in lead, right?
    Can I cut the cast iron pipe and connect plastic? If so, where would I cut it? I'm going to move the drain about 14" to center it for the shower.
    Thank you for your help!
    Susan
      File size:
      19.9 KB
      301
      File size:
      20.9 KB
      293
  8. Terry
    Aug 17, 2004
    If you cut the cast, cut it behind the hub.
    But first measure to see what diameter it is.
    Most new cast iron is 2-3/8"
    Some of the old stuff is 2-1/8"
    When I couple the small stuff, I use a Copper by cast coupling.
    Or, it looks like a rubber seal is stuck in the hub, if so, you may be able to pull out the last pipe.
    Toothpick? There was plenty of wood there already in that non load bearing wall. That had been done by the handyman before me.
  9. waggscreek
    Feb 6, 2008
    Mom
    Seattle
    It is a rubber seal so when you say "pull the pipe out" is that literal? Can I just yank it out? I did tug on it a bit, but was afraid to really pull it for fear of pulling out everything, the larger pipe and all (possible?) I've never touched a plumbing pipe before in my life so this is all new to me. I'm about as new as they come to DIY projects but so far so good.
    Susan
  10. Terry
    Aug 17, 2004
    Yes, you may be able to muscle it out.
Similar Threads: Cast Iron
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Yesterday at 1:12 PM
Plumbing Forum, Professional & DIY Advice Cast iron sewer problems. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron tub ledger board placement Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron riser to toilet flange Feb 5, 2017
Plumbing Forum, Professional & DIY Advice 1950s cast iron sewer line clogged Jan 28, 2017
