Cast iron pipe leaking in basement wall
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sesquialtera, Apr 17, 2009.
  1. sesquialtera
    sesquialtera New Member
    Apr 17, 2009
    I wondering what this will require to fix, and whether I might try a temporary patch until I settle on a solution.
    Here's the situation: vertical cast iron waste pipe set in pocket in stone foundation wall; the pocket is concreted over (i.e. encases the pipe) to a height about 5' from floor. the 18" segment between the top of the concrete and the first hub is corroded in the back and leaking water. As shown the in pictures, that segment also contains two wyes that are fabricated from saddles u-bolted to the straight pipe. I first thought that a saddle seam was leaking, but it turns out they are tight and its the straight pipe that is a goner.
    Could I encase the corroded areas in epoxy as a stop-gap until I can schedule proper repair? How much demolition is the repair likely to require?
    Thanks,
    Paul
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    1 - A plumber
    2 - A jack hammer
    3 - money in your checking account
    [​IMG]
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Wow...
    I hope you're not in my service area planning on calling in for service tomorrow...:eek:
    I hate it when they send me those kind of jobs Saturday after the supply house closes...
    This job is bigger than Mighty Putty even with the triple offer!
    [​IMG]
  5. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    I will go there with bells on. I love them type of jobs, also have two garages full of random supplies that I have collected over the years. like the Upright wye with a side inlet they use in basements for piping in the laundry sinks.
Similar Threads: Cast iron
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Tuesday at 1:12 PM
Plumbing Forum, Professional & DIY Advice Cast iron sewer problems. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron tub ledger board placement Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron riser to toilet flange Feb 5, 2017
Plumbing Forum, Professional & DIY Advice 1950s cast iron sewer line clogged Jan 28, 2017
