cast iron lead packed hub removing pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by hellomoto, Dec 3, 2005.
  1. hellomoto
    hellomoto New Member
    Nov 9, 2005
    What is the best way to remove a galvanized pipe that is connected to the main waste pipe that is cast iron and the hub looks like it is lead packed? I found a book diagramed how cast iron pipes use lead packing, but doesn't say anything about what is the easiest and quickest way to remove the joint. I found a thread in this forum suggesting that a trusty screwdriver is needed to chisel out the lead, etc. Is it possible to torch the joint to soften the lead? Once the bond is soft, then the pipe can be twisted off. Any suggestions?
    Thx in advance
  2. jadnashua
    A drill bit to remove the lead, then a small chisel or screwdriver to pick out the remaining? Seems that that is what I've read. You'd probably never get it hot enough to melt that lead. To make it, you typically use a lead pot to melt the lead, then a ladel to pour it into the joint.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    I have removed vertical lead joints with a torch and map gas. If I can I break the pipe (ci pipe) with a hammer so all that is left is the lead. Slice the lead in 3 places with a sawsall, and pry the lead out with a large screwdriver.
  5. hj
    Pipe
    If you have room to pull the pipe out, then wiggle it around in all directions to loosen the lead, then it may be able to be pulled out while twisting it. Sometimes plumbers deformed the end of the pipe and if they did that then you have to remove all the material from the joint to get the pipe out. There are many ways to remove the lead, but it depends on where the joint is, its direction, the width of the lead joint, and the tools you have available. Heating the lead does not do any good for most people because it hardens again immediately after you remove the flame, and hot lead is not really soft lead anyway unless it is melted.
  6. finnegan
    finnegan New Member
    Aug 16, 2005
    CT
    I am on board with hj. You an usually just wiggle the pipe out of the joint.
  7. hellomoto
    Nov 9, 2005
    Remove lead packing
    :cool: Thanks guys. I guess I will prepare to spend this coming weekend in the craw space to replace that pipe. I'll first try to loosen the pipe first before working on prying the lead out. Hopefully, it comes off easily.
  8. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    lead
    If it's a horozontal joint then you can melt it out as long as you have room to get the torch on it. I use a Turbo-Torch with the large tip.
Similar Threads: cast iron
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Today at 1:12 PM
Plumbing Forum, Professional & DIY Advice Cast iron sewer problems. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron tub ledger board placement Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron riser to toilet flange Feb 5, 2017
Plumbing Forum, Professional & DIY Advice 1950s cast iron sewer line clogged Jan 28, 2017
