FullySprinklered
Customer purchased a cast iron Kohler tub. The bright spot of the day was the fact that I had help bringing this monster in and setting it in the bathroom. It was sort of like putting a '64 Cadillac Brougham in a shoebox. but they pulled it off.
I've never spent eight hours installing a tub before, so it was a unique experience for me. The old tub had the w/o above the floor, the new tub w/o was below the floor. The hole in the subfloor for the drain was maybe 8x10" and had three joists running across it, three inches apart. I'll stop there in the interest of brevity.
Here's the problem that brought the job even closer to the gates of hell: the tub has a slope on the drain end that precludes being able to use a normal waste and overflow. In other words. installed, the glue-up JB lift and turn w/o was way far from being plumb enough to connect to the tee from the drain. I ended up going shopping to get a couple of 22.5 els in 1.5in. I rotated them around until I could them vertical, then glued everything up while the muscle stood around waiting.
It being a Kohler, I can only assume that there is a proprietary waste and overflow for this tub.
