Cast iron flange to J Tech flange
Discussion in 'Toilet Forum discussions' started by JP in VB, Jul 21, 2010.
  1. JP in VB
    JP in VB New Member
    Jul 21, 2010
    Virginia Beach, Va.
    Purchased a home built in 1965, noticed one of toilets leaking into crawl space when flushed. Removed toilet and noticed two wax rings had been compressed into the cast iron drain. Looking at using a J Tech flange to raise flange to floor height and reducing the cast diameter to be able to use standard wax rings. The inside diameter of the cast iron pipe is 5", the largest J Tech flange I can find says it fits into a 4" cast pipe. What are my options?
    Thanks for any help!
  2. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    Thats weird, I can't conceive someone using 5in cast in a house, any chance you can post a picture?
  4. hj
    You have a 4" cast iron flange but since the riser does NOT come up to the floor level, you have a 5" opening. I would create a 4" "Dutchman" to insert into it to bring it up to the floor level, and then secure it in place with a lead/oakum joint.
Similar Threads: Cast iron
Toilet Forum discussions How to connect back outlet toilet to cast iron soil stack? Oct 22, 2016
Toilet Forum discussions Cast Iron Soil Pipe & ABS/PVC Offset Flange Sep 11, 2016
Toilet Forum discussions Basement Toilet, no flange & looks like cast iron Jul 3, 2016
Toilet Forum discussions Toto legato & cast iron pipes Jun 1, 2016
Toilet Forum discussions Removing 1" of Cast Iron Feb 28, 2016
