Pat Carney
My toilet was rocking and leaking, so I pulled it and discovered that the flange is not level, not bolted down and has this metal ring between the flange and the metal pipe (photo)? Will it be possible to remove this and replace it with a compression flange? Since I am not too experienced, would it be best to call a plumber to do this part? I do not want to use shims again to level the toilet. Thank You!!
