Cast Iron: Cutting and joining to PVC
Discussion in 'Remodel Forum & Blog' started by remodelingit, May 28, 2005.
  1. remodelingit
    remodelingit New Member
    May 21, 2005
    Texas
    Two questions regarding my cast iron drain line:
    1: What is the best way to cut a 3" cast iron drain in the crawl space(15"). A sawsall seams to be the logical and most efficient way, but I'm not sure what blade to use. Or should I rent a chain cutter.
    2: What is the best method for joining 3" PVC to 3" cast iron drain line. The drain line is about 2" below the surface of the dirt in the crawl space.
  2. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    [​IMG]
    Snap cutter
    You can use a snap-cutter, but I would use a reciprocating saw with metal-cutting blades. Cut it as straight as possible.
    Connect the PVC to the cast iron with a no-hub coupling (aka Mission coupling), which has a neoprene rubber sleeve covered by a stainless steel sleeve with torque bands to seal it. You can get them at any plumbing supply.
    Good Luck!
    Mike
  4. remodelingit
    May 21, 2005
    Texas
    Coupler
    Thanks. Does the coupler have to be covered in stainless steel?
  5. jadnashua
    Yes, if you want it up to code...and to last. One style is a neoprene sleeve with hose clamps at either end. This is prone to abrasion, Flex, and (eventually) degradation of the sleeve. The other is also a neoprene sleeve, but encased in stainless steel and multiple clamps to distribute the pressure - the neoprene is just used as a sealer, the strength is in the metal. The other relies on the rubber for all of the strength of the joint.
  6. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    I like the snap cutters MUCH more than a recip. saw even with blades made for cutting cast iron. Just seems to be quicker and easier...for me at least. Of course, there are situations in which you cant get the chain around the pipe to snap it. In those cases I sigh heavily and go get the sawzall. lol
    Good luck!
  7. remodelingit
    May 21, 2005
    Texas
    Cutter and coupler
    Rented a snap cutter- $10.00 well spent. On my way to get the stainless covered coupler. Thanks for the advice!
  8. remodelingit
    May 21, 2005
    Texas
    I installed the coupler but it just doesn't look right due to the different diameter of the two pipes. The OD of the cast iron is smaller than the PVC. I used the coupler with the solid stainless steel band. Do they make one that is smaller on one side to accommodate the difference? Should I have used the one with ridges in the stainless steel sleeve?
    Thanks.
  9. Terry
    Aug 17, 2004
    If you have the older cast iron, 3.125" in diameter, you can use a mission coupling that is "copper" X "no-hub cast".
    The copper side works well on the old cast, and the no-hub side will slip over the PVC.
  10. remodelingit
    May 21, 2005
    Texas
    Thanks- got the coupler from a plumbing supply store. Fits like a glove.
    As I move through my project I'm becoming more and more skeptical of the advice folks at the orange box give. This isn't the first time I was pointed to the wrong fitting.
Similar Threads: Cast Iron
Remodel Forum & Blog Tips and Tricks on Removing Top Mount Cast Iron Sink Jul 2, 2012
Remodel Forum & Blog Permanently Remove Cast Iron Baseboard Radiator Dec 31, 2011
Remodel Forum & Blog replacing cast iron radiator supplys Jul 22, 2010
Remodel Forum & Blog Replacing subfloor around cast iron toilet flange..... Nov 5, 2008
Remodel Forum & Blog adding attic bathroom. cast iron stack questions Sep 22, 2008
