Cast iron Connection Problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pwelsh130, Jan 1, 2010.
  1. pwelsh130
    pwelsh130 New Member
    Jan 1, 2010
    melbourne,fl
    I have a Cast Iron Vent Stack that the Kitchen sink assembly connects into. The problem is the horizontal drain pipe that connected into the sink was cracked next to the vent stack connection. I can not remove the threaded nut that attached the original horizontal pipe (took the broken pipe out but not the nut) to the vent stack. It is tucked into a concrete block wall and the pipe wrench can't get a grip. Any suggestions?
    I have tried penetrating compound....Attaching a pvc pipe with epoxy. I put a torch to it but no help. I'm out of options. I've attached some pics.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I appears to me that you have reach the point that you need professional help. We DIYers have to realize that there is a point where our individual skills, tools, and know-how stop and it is time to set our egos aside and call in the Cavalry.
  4. Terry
    Aug 17, 2004
    If it's a threaded connection, it should come out.
    It may take a lot of muscle though
    Sometimes warming the tee helps.
  5. RTAPlumbing
    RTAPlumbing Plumber
    Jan 1, 2010
    lawrenceville, GA
    Use a bigger pipe wrench. It will come out. Try applying heat from the inside with your torch. You can always cut it out and just get another sanitary tee. good luck
  6. dcelite
    dcelite Plumber
    Oct 5, 2009
    Los Gatos, CA
    It looks like a trap adaptor which used to be soldered in. You can use a sawzall or hack saw blade and cut out a section of the threaded piece from the inside. Put the saw blade inside the fitting and cut straight down through the threads until you hit the cast iron. Then move around about a half inch and make a similar cut. Then pry out the little piece you just cut and you'll be able to spin out the rest of the adaptor.
  7. hj
    pipe
    It is a solder bushing for a tubular trap. Remove the vestiges of the trap by heating the solder and pulling the piece out. Then make two cuts, about 1/8" apart through the brass and remove the sliver between the cuts. Then use a chisel to fold the brass together to close up the slot, and it will unscrew, probably by hand.
  8. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    I run into them solder bushings all the time I use a caping chisel to remove them with out damaging the tee or the threads.
  9. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
  10. hj
    wrench
    Then you haven't broken the outlet of the tee off yet?
  11. SewerRatz
    Nov 20, 2008
    Chicago, IL
    Never with my cape chisel. I always have had good luck with it caving in the pipe or fitting I wanted to remove with out blowing out the tee.
  12. ilya
    ilya In the Trades
    Dec 10, 2009
    home repair -I am not licensed and never represent
    Akron Ohio
    I'm not a longtime pro, but dcelites method has always worked for me. Make sure the two cuts are NOT a "pie wedge" or it'll never come out. I always try to do the opposite-my two cuts are closer together at the threads. Then knock it out w/ a chisel, and unscrew. Once or twice I've had to repeat the process on the opposite side of the fitting,cutting it in two. Then a tap w/ the chisel knocked each half loose.
Similar Threads: Cast iron
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Tuesday at 1:12 PM
Plumbing Forum, Professional & DIY Advice Cast iron sewer problems. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron tub ledger board placement Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron riser to toilet flange Feb 5, 2017
Plumbing Forum, Professional & DIY Advice 1950s cast iron sewer line clogged Jan 28, 2017
