Case 3000 replacement with Gerber Maxwell
Discussion in 'Toilet Forum discussions' started by SD1972, Mar 2, 2016.
  1. SD1972
    SD1972 New Member
    Mar 2, 2016
    Indiana
    Hello, I recently purchased a home built in 1965 and it has a pink Case 3000 toilet installed. It is not in working order and my wife hates the color.
    I've been trying to search for information before asking the same questions everyone else has asked.
    I see a carrier photo in one of the other threads. Is this going to be the standard carrier I should expect to see when I remove the existing Case3000 and open the wall? Is it as simple as placing 2 new bolts in the top of the carrier, replacing the seal, closing up the wall and installing the new Gerber Maxwell?
    http://terrylove.com/forums/index.php?threads/case-3000-wall-mounted-toilet.17626/
  2. Terry
    Aug 17, 2004
    [​IMG]
    Most of the wall hung toilets that use a bolt on tank use the standard 4 bolt carrier.
    You may need to open the wall and make that modification.
Similar Threads: Case 3000
Toilet Forum discussions Case 3000 Fill Valve Repair Feb 20, 2016
Toilet Forum discussions Case 3000 Jan 26, 2016
Toilet Forum discussions need advice on replacing case 3000 Nov 19, 2015
Toilet Forum discussions Case 3000 toilet Nov 18, 2015
Toilet Forum discussions Case 3000 Wall Hung Sep 2, 2015
