Cliffy
I have a customer that has 4 case 3000 wall mount toilets that I will be replacing as they need it. One isnt working right now and another one is on its last leg. This is the first time I have come across wall mount or rear flush toilets. You just don't see them around here.
My questions is what do I do? Replace it with another wall mount? Or a floor mount that is rear evacuating? I've done hours of searching and see the that the American standard wall mount had tons of problems. I came across a blog were a guy used a Gerber floor mount that worked good I'm just. It sure if the soil line would line up. Best I can tell it would be 1/8th off. Pretty sure I could make that work. Any advise?
I keep reading that a neoprene seal should be used. Any Preferance of brand or model?
Thanks for answering this post, and all the others. I've been perusing them for days as I try to come up with a plan to recommend on these toilets.
Cliff
Cliff
