cartridge for water main shut off
Discussion in 'Shower & Bathtub Forum & Blog' started by cs91655, Oct 2, 2009.
  1. cs91655
    cs91655 New Member
    Oct 2, 2009
    Irving, Texas
    I have a leak in my shower faucet. I shut off the water at the main at the street but I still have water flowing out of the faucets in both bathrooms. is this my responsiblity or the city. If it is mine please tell me what to do...I don't know what a cartridge is. On your forum you said to replace the cartridge...
  2. jadnashua
    You usually own the pipe after the meter. The utility's shutoff often requires a special tool to turn it off (if that leaks, it's usually their problem). So, it's hard to say, not knowing which valve you shut off. replacing you main shutoff usually requires shutting the city's valve off so you can install or repair yours to fix the problem. There are ways around that, but each situation is different.
    Also, not knowing what brand and model of shower valve you have makes only generic help, and may not be what you need.
    On many shower valves, the entire guts of the valve is in a cartridge, so replacing it often solves many wear problems. But, some are rebuildable, and don't have a cartridge...a picture would help clear this up and get you better help.
Similar Threads: cartridge water
Shower & Bathtub Forum & Blog Low water flow to a shower head can be caused by a low-flow rough-in valve/cartridge Apr 9, 2016
Shower & Bathtub Forum & Blog Replaced Delta Shower/Tub Cartridge Now Water Pressure Is Worse! May 19, 2015
Shower & Bathtub Forum & Blog Help removing Delta cartridge, and is my water actually off? Feb 19, 2015
Shower & Bathtub Forum & Blog Minimal hot water after replacing cartridge Jan 21, 2015
Shower & Bathtub Forum & Blog Grohe 47 111 thermostat valve/thermoelement cartridge doesn't let cold water through May 20, 2013
