Cartridge faucet still dripping from spout after cartridge has been replaced?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DarkNova, Feb 15, 2010.
  1. DarkNova
    DarkNova New Member
    Mar 29, 2007
    Wisconsin
    I have a 2 handled cartridge faucet that had been dripping from the spout, about one drip every 10 seconds maybe. The drips coming out were hot so I bought a new cartridge for the hot side, covered it with silicone grease, and replaced it. The faucet still dripped. I then tried taking the cartridge out, soaking the place the cartridge sits in with vinegar for 8 hours and scrubbed with a toothbrush, in case there were mineral deposits allowing water to slip by the O-ring, but that didn't help either. Does anyone have any other suggestions to try? Or has the faucet just corroded enough that there's a channel for water to bypass the bottom O-ring and so I need to replace the whole faucet? Thanks.
  2. hj
    Unless the old part was leaking past the cartridge/stem, the body of the faucet is NOT damaged, but the piece you are using may not be the proper one, or could be an "aftermarket" model which is not to OEM specifications.
  4. DarkNova
    DarkNova New Member
    Mar 29, 2007
    Wisconsin
    I should clarify and make sure its understood that the faucet leaked in the same way with the old cartridge. I replaced the cartridge because I thought it was worn but it has the same issue with the new one, which is why I am wondering if it is the faucet body. The replacement cartridge looks exactly the same, however, it is aftermarket (bought at *******) as I don't know what kind of faucet it is.
Similar Threads: Cartridge faucet
Plumbing Forum, Professional & DIY Advice Help Removing Grohe (Grohmix) faucet Cartridge Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Replaced Delta 2 handle faucet cartridges now there is small leak from valve stem Oct 30, 2016
Plumbing Forum, Professional & DIY Advice Help, id this old faucet valve cartridge? Oct 10, 2016
Plumbing Forum, Professional & DIY Advice Need help identifying single lever sink faucet cartridge Jul 19, 2016
Plumbing Forum, Professional & DIY Advice American Standard 2 knob faucet cartridge - tightening - valve open or closed? Jul 16, 2016
