j.c.wright
I have a Carrier CNPVP3017ATAACAA cased N coil in a down flow configuration with the furnace mounted on top of the coil and have a few questions. The first issue I have is that there is a lot of air flow from the condensate drain lines which would suggest that the condensation water is being blown around inside the coil case. This will eventually case water damage to my flooring and a mold situation. Should there be some sort of a block off plate to divert the air or would it be better to mount the coil on top of the furnace.
