Caroma Dual Flush watersense toilet review & pictues
Buy a different toilet! No, unless the thing is not working right, the bowl is overfilled....it has an opening behind you can't see that drains any water above the maximum down the drain. If you pour a bucket of water in the bowl (pour it too fast and it will flush), then let it sit, that's the maximum level it can get.
Many dual flush bowls, like the Caroma, Kohler Persuade, and the Toto Aquia have little water in the bowl. That's the nature of them. The Caroma glaze seems a bit rough though, Terry
Brandy
Ontario
Does anyone have an opinion about which is a better toilet - the Toto Aquia or the Caroma Caravell?
TomMyers
New York
Caroma Sydney 270 Easy Height or Aquila III
I am torn. I can get the Toto Aquilla locally, but have to have the Caroma shipped in.
My wishes/needs are:
- ADA height (17-18") for easy elderly access
- Bisque (or Biscuit) color
- Dual Flush
- Does not require cleaning after every BM.
- Less likely to clog.
My research leads me to the Sydney 270, but am not sure about the "cleaning after BM" issues with it compared to the Aquilla.
Any thoughts or recommendations?
Cass
If your BM is excessively large go with the Caroma. Its trap way is large enough to not clog.
Like one of my customers said...WoW I can cancel my trash pick up and flush every thing down this toilet...
kf
New York
Hi Terry,
Which Aquia are referring to? On your order site your pull down menu for the Aquias has the Aquia II as an option. What are the differences between the two? Thanks...
The Aquia CST414M has the larger adapter, and a bit better MaP score. Also takes a little more time to install than the CST416M and the CST464MF
Other than that, they work pretty much the same, the CST464MF has the taller bowl at 16-1/8"
The other two are 15-1/8"
Reader Review
Comments by readers
We recently bought the Caroma Sydney 2 pcs. (Tank 622322W, Bowl 609159W). After we installed the toilet, we encountered problems with the flush. As you can see in my video http://video.google.ca/videoplay?docid=-1855798188535347905 from the internet, with every flush the water will splash up everywhere on the seat and cover. When there is a number 2, there are shit droplets on the seat, very disgusting.
We contacted the company with no response. Could you tell me how to fix my problem?
cslee
Probedude
California
cslee
I've looked at a few Caroma videos on YouTube and they all look like they do the same. All the water dumps from the rim, none of it below the water surface.
Caroma-305
Texas
issue with CAROMA 305 DUAL FLUSH
installed CAROMA 305 DUAL FLUSH few days back.
one bigggg issue is , the "water level" in the BOWL (not the tank), is so low, the porcelain gets dirty, and requires cleaning,
the "water" filled matches the "water level marker" in the TANK.
the 'three' tower like components are so complicated for me to understand, and very flimsy.
any way out , to increase the water-level in the bOWL.
please help
Normally, no. If for some reason the fill valve is not working properly, in theory it is possible.
Take a bucket of water. Slowly pour it into the bowl. Let it sit for a minute or so, then check the level. If it goes up and stays up, it's a fill valve issue. If it won't stay up any higher, that's just the way that toilet is designed, nothing you can do about it except replace it with a different model.
Note, the dual-flush toilets can't have all that much in the bowl, because even on a low flush, it still needs to evacuate the entire amount, and refill. To keep the volume down, they can't have all that much in the bowl.
The Caroma has very little water in the bowl,
and they stay dirty.
But that has been commented on before.
I don't sell very many of the Caroma anymore.
How do you like the droplets of water on the seat when you flush it?
That's a nice bonus too.
Gary Swart
Yakima, WA
The water level (aka water spot) in the bowl of any toilet is determined by the construction of the internal trap and is not adjustable. One of the things I really like about my Toto Dartmouth and Toto Drake is the large water spot.
Midwest
Yep, I like the way Toto designed the wide but shallow waterspot. The problem being described with the Caroma is one of two reasons I decided against them. (The other was the potential for spraying material out of the bowl as I've seen in a vid.)
Caroma-305
Texas
thanks
thanks for the info, What model of DRAKE do you recommend.
Caroma-305
Texas
replace?
thank you for the info. Its only 3 days old, will local-hardware store take it back, and replace it for TOTO models. (iam hesitant to do this, but iam dissatisfied with the product)
