caroma dual flush - toilet seat headaches
Discussion in 'Toilet Forum discussions' started by godhelpme, May 10, 2008.
  1. godhelpme
    godhelpme New Member
    May 9, 2008
    Regretably we installed a caroma dual flush one peice toilet where it is more or less surrounded by three walls for a small degree of privacy - we did all this before attaching the toilet seat and now can not adequately tighten done the seat as the only access to the bolts is from the back of the toilet and then back quite a ways towards the front. There is about seven inches between walls and toilet. The look is of course great because the bolts and such are completely out of sight on the interior of the full skirt. Any suggestions? Any special tool thatmight be of some assitance? Tried getting a smaller child to shimmy his arm in and around to no avail...
  2. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    Is this a Caravelle unit?
    You'll most likely have to lift the toilet off from its unifit flange and then tighten the bolts properly. You can only tighten the bolts so much by hand by reaching around from behind...that's if you have decent access from the side...which you don't. Atleast you won't have to mess with a new wax ring to re-set the toilet. It's too bad they didn't use fancy bolts like Toto uses on their skirted toilets that actually tighten from the top since there is no access.
  4. Cass
    Cass Plumber
    Nov 12, 2005
Similar Threads: caroma dual
Toilet Forum discussions Desperately seeking parts for a Caroma Toilet - need dual flush seal washers Mar 11, 2011
Toilet Forum discussions Caroma Royale 305 RF Dual Flush Aug 8, 2009
Toilet Forum discussions Flush Mechanism Problem on Caroma Dual Flush Jan 11, 2009
Toilet Forum discussions Toto Aquia verses Caroma dual flush Jan 21, 2008
Toilet Forum discussions Caroma Dual Flush watersense toilet review & pictues Jul 12, 2006
