Caroma Caravelle 270 shut-off valve doesn't
Discussion in 'Toilet Forum discussions' started by birkelbk, Jul 29, 2011.
  1. birkelbk
    birkelbk New Member
    Jul 29, 2011
    San Antonio, TX
    I have a Caroma Caravelle 270 with the dual flush, which is about 3 years old now. I live in an area with extremely hard water and I suspect that a lime build-up may be keeping the shutoff valve from closing completely, allowing water to leak into the bowl all the time. I knew how to fix the old toilets with floats, but I don't know the first thing about where to look to get this working. Does anyone have a link with information on how to fix or replace the valve in this toilet? Mine is similar to this one:
    http://www.terrylove.com/forums/attachment.php?attachmentid=12697&stc=1&d=1301794382
    [​IMG]
    Thanks for any advice or suggestions.
    Karen
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Karen, if it is the shut off valve, the extra water will be going down the overflow pipe into the bowl. If that is not the case, then the flapper is likely leaking. Flappers are easier and cheaper to replace than valves. Might be a good idea to check this out before tearing into or replacing the shutoff valve.
  4. birkelbk
    birkelbk New Member
    Jul 29, 2011
    San Antonio, TX
    I will definitely check that first. Thanks for the reminder.
  5. birkelbk
    birkelbk New Member
    Jul 29, 2011
    San Antonio, TX
    Nope, it's the shutoff valve. When I manually close it after a flush, water still runs through, and when it reaches the fill line, water continues to flow in and into the overflow pipe eventually. How do I go about fixing that?
Similar Threads: Caroma Caravelle
Toilet Forum discussions Caroma Caravelle 270 just installed ... doesn't seem to be flushing well Apr 2, 2011
Toilet Forum discussions Caroma Caravelle vs Toto Drake for water savings? Nov 11, 2009
Toilet Forum discussions Caroma Caravelle Installation concern Aug 11, 2009
Toilet Forum discussions Help! Aquia or Caroma Caravelle Mar 5, 2009
Toilet Forum discussions Caroma Caravelle streaks Nov 30, 2008
