Carbon tank not working
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Mrs. Smith, Nov 6, 2008.
  1. Mrs. Smith
    Mrs. Smith New Member
    Nov 6, 2008
    We purchased a home 2 years ago with a carbon tank set up. It has pot tank connected to it for Bleach addition every 3 months. This was the only means of iron removal in the home and it worked great for 2 years. Now the rust is coming in full force. Can I add a product such as Iron Out or Potassium Permanganate to the pot tank to help remove rust build up in the carbon tank?
  2. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    Activated carbon is like a molecular sponge, except that it adsorbs contaminants at different affinity rates. In other words, it "likes" certain chemicals more than others. If the "sponge" is full and a more attractive guy comes through, it can toss out some less attractive bloke to make room. That particular contaminant may not be to your liking.
    Find out the age of the tank and when it was last regenerated, and hire an expert to get the system serviced.
  4. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    That is a great explaination of how carbon works.
    Most carbon filters when used to remove chlorine won't last much beyond two years in average use. They are definately not used as iron filters. This will just gum them up even more. If you have iron, get an iron filter. Then you can use chlrorine, potassium permangenate or air which ever you prefer.
  5. Gary Slusser
    I think you are wrong about it being a carbon filter. You don't regenerate carbon and to use the bleach, the filter has to regenerate. Carbon is only backwashed.
    I think you have a Pyrolox filter, they (can) use bleach. Or it's a manganese greensand filter. Greensand is the only mineral that commonally uses potassium permanganate, a serious poison.
    Never mix potassium permanganate with anything but especially not with chlorine or Iron Out or similar products.
    Bleach sitting in a non sealed tank will weaken substantially, especially over 3 months. Replace the bleach and start a manual regeneration. When the control starts to suck bleach, watch it and just before the bleach runs out, unplug the unit for 20 minutes. Then plug it in and when it goes into backwash, unplug it and let it backwash for 15 minutes and plug it in again and let it finish from there on its own. That may or may not clean the mineral.
    BTW, carbon also absorbs 'contaminants'.
Similar Threads: Carbon tank
Pumps and Tanks Well Forum & Blog. Water is life. Is my granular carbon tank contaminated? Aug 25, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Longevity of Carbon Steel Lakos Sandmaster? Jun 19, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Centaur Catalytic Carbon Question??? May 25, 2012
Pumps and Tanks Well Forum & Blog. Water is life. How to change the "BIG BLUE" carbon sediment filter??? Dec 27, 2011
Pumps and Tanks Well Forum & Blog. Water is life. seeking fridge filter without carbon May 2, 2009
