Capping off old sewer pipe inside house
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by natemac, Apr 18, 2008.
  1. natemac
    natemac New Member
    Apr 18, 2008
    We have an uncapped old sewer line in our basement that was walled in by the previous owners. We only know this because when we had a plumber out to snake our sewer line (for tree roots), they accidentally sent the snake in the wrong way and managed to pull out some insulation. When they sent the camera in to look we found a pipe filled with insulation and when he pushed the camera farther through we were looking at 2x4's and walls. We know basically where the problem is but it will require tearing out walls in my downstairs finished bathroom.
    My question is, once I find the uncapped pipe, can I just put a regular pipe cap on it or do I need some special cap to keep the sewer gases from building up? Thanks for any help!
  2. Ian Gills
    Jul 24, 2007
    USA
    I have one of those in my basement. I just use a rubber cap that looks like a fernco.
    Like this: [​IMG]
    My line was left uncapped for years. It didn't smell. Hate to think how blocked it must have been. I'll soon find out when I finish the basement.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Fernco Qwik Cap.
    [​IMG]
  5. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    The "gem" cap style will work but I prefer to use the cast iron hard caps with no-hub bands if the piping is cast and clue-on caps if plastic...
    The rubber ones do deteriorate and crack over time....
  6. westcoastplumber
    westcoastplumber Plumbing Contractor
    Nov 30, 2007
    c-36 plumbing contractor
    los angeles
    Use a Blind Plug, cast iron, and a no hub cplg.
    I would not use a rubber jim cap or fernco because a cable cutter will penetrate it and you will be back to square one.
    Also, I would never bury anything rubber like a cap in the wall anyways.
    If you want it solved forever, use a cast blnd plug and no hub torqued to 60 lbs:D
  7. gear junkie
    gear junkie Plumber
    Feb 14, 2008
    government
    Virginia Beach, IPC country
    Not sure what code you go by but you're not allowed to just put a cap on the pipe because that constitutes a "dead end" which is not allowed in IPC. I would punch a hole through the wall and continue the pipe outside with a cleanout cap to make a cleanout. You already have a root problem so look for solutions to solve futrure problems. Next time the plumber could use this cleanout to access your entire line, even under the house.
  8. westcoastplumber
    Nov 30, 2007
    los angeles
    Hello Ben!!!!!
Similar Threads: Capping sewer
Plumbing Forum, Professional & DIY Advice Capping a gas fireplace Jan 30, 2016
Plumbing Forum, Professional & DIY Advice Concerns for capping a tub connection of a shower valve Jan 25, 2016
Plumbing Forum, Professional & DIY Advice Capping Off Sprinker May 6, 2015
Plumbing Forum, Professional & DIY Advice Capping off Wye adaptor for kitchen drain Feb 25, 2014
Plumbing Forum, Professional & DIY Advice Removing and capping an OLD toilet. Jan 23, 2014
