Capping gas line.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Jason75, Apr 6, 2013.
  1. Jason75
    Jason75 New Member
    Apr 6, 2013
    Illinois
    So I have a general question for plumbers located in Illinois I am looking to purchase a home in Warrenville IL. And the home that I am looking at has a gas cap in the laundry from and in the fire place but no shut off valves. There is a main shut off valve. I have talked to a few people with mixed responses does a capped gas line need a shut off valve? I would like to see the seller of the home get this work completed but need some information to go back to them and ask to have this completed before closing.
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    They don't need valves unless it is connected to an appliance. In fact ending the line with just a valve is far more dangerous. When they do end with a valve the valve must be plugged for safety reasons.
    John
  4. Terry
    Aug 17, 2004
    Like John has mentioned. A capped line is as safe as it gets. You're golden.
    Some gas lines are considered "futures"
    When someone decides to use them, they take off the caps and then valve them and install the fixture.
    A valve can have a slight leak. A cap doesn't.
    That's why when we put on a gas test for the inspector, we cap off "before" any valves.
  5. Jason75
    Jason75 New Member
    Apr 6, 2013
    Illinois
    Ok, so what I gather is that if I was to then install the dryer as gas I would then have to install a shut off valve. So the seller is not responsible to have this completed before I close. Thanks for all the help.
  6. Terry
    Aug 17, 2004
    If and when someone decides to install a dryer, it's best to do it at that time. Whoever pulls off the cap, can put the shutoff valve on and connect a flex to the dryer. One step instead of two.
  7. Jason75
    Jason75 New Member
    Apr 6, 2013
    Illinois
    Yeah, see I was under the assumption that the shut off valve should have already been there.
  8. hj
    However, Depending on the fireplace, it probably SHOULD have a "shutoff" valve in the wall adjacent to the fireplace.
  9. Jason75
    Jason75 New Member
    Apr 6, 2013
    Illinois
    The gas line has a key that controls the gas flow but its currently covered by brick
  10. hj
    Unless it is "accessible" it is not proper, or approved.
Similar Threads: Capping line
Plumbing Forum, Professional & DIY Advice Need advice capping copper lines to wetbar. Slab foundation May 2, 2013
Plumbing Forum, Professional & DIY Advice Capping old drain lines Apr 18, 2013
Plumbing Forum, Professional & DIY Advice Capping a live water line Jan 7, 2012
Plumbing Forum, Professional & DIY Advice Capping a supply line? Jul 3, 2011
Plumbing Forum, Professional & DIY Advice Capping an outdoor gas line? Mar 22, 2008
