MiamiCanes
I'm stuck. I can't find a tool that can actually work with the drain on my bathtub. The problem is that it has a post in the middle that's about 3/8" longer than the cavity inside the dumbbell wrenches I've bought so far from Home Depot, Lowes and Harbor Freight. I can't cut it off, because it doesn't stick out above the drain far enough to use a hacksaw.
I tried Plan B & used a cheap pair of pliers to stick a handle end down each side of the drain, then used a pipe wrench to try turning them. The only thing THAT achieved was a bent, now useless, pair of pliers.
I *can* turn the post by gripping it hard with pliers and rotating it clockwise or counterclockwise, but it doesn't seem to do anything besides rotate... it doesn't loosen, it doesn't tighten, and doesn't end up any higher or lower.
