Can't remove Delta "bonnet" to replace cartridge!
mshantea
Alabama
Thanks to all on this thread. I tried the vinegar. No joy. Also too much pressure when using both channel locks and pipe wrench. I actually moved the actual plumbing in the wall a bit. Heat was the trick. Used a Ryobi heat gun. I went ahead and replaced the bonnet with a new one. Why not while in there. $6.
Did it by myself. No need for anyone else.
Chris2300
California
I used a strap wrench and I thought the bonnet nut was coming off but I realized that I had slightly turned the whole body. I turned the water back on and don't see any leaks. Am I in the clear since there are no leaks or did I do any damage by turning the whole body while trying to get the bonnet nut off? Thanks.
Sameer
Michigan
I started fixing my leaky faucet and I bought a replacement cartridge, my problem is I cannot get the nut back on once cartridge is there. If I do not put the cartridge the nut can tighten but if I put the cartridge the nut just does not see to be getting into the groove to be tightened. I have tried using the old cartridge as well as using some force while tightening.
I would take a good look with the cartridge out. It may be there the old springs and washers are still in the body of the valve.
Hector Solis
Texas
I could not remove the bonnet, even with an 18" pipe wrench. I tried the hot water and vinegar trick. Wrapped a soaked rag and left it for about 4 hours. After that, the bonnet came off rather easily using channel pliers. I did not expect the vinegar to work since others on this thread had no luck.
Daluu
San Francisco, CA
I am not sure what you are talking about, but I hope you are NOT turning the water on without the bonnet nut in place.
is that likely going to eject/shoot the cartridge out of the valve? and water spattering out
Daluu
San Francisco, CA
Try to get a wrench on the body of that valve, another on the bonnet nut.
If the body twists, you'll be spending close to $600 to fix it.
What do you mean body twists? A part of the valve cracks or breaks off? Or the valve connections to the plumbing pipes leak or break?
