Can't remove anode rod or fill tube???
Discussion in 'Water Heater Forum, Tanks' started by Handiman, Apr 19, 2009.
  1. Handiman
    Handiman New Member
    Apr 18, 2009
    Nevada
    Hello, I'm trying to lengthen the usable life of my water heater by replacing the anode rod (ZINC?) and using an angled fill (dip) tube (to really get all the debris out).
    Problem is I can't get either one off. It's almost as if they are welded on there with rust and corrosion. I tried pretty hard using a breaker bar but I don't want to break the actual fittings so I stopped. I used all kinds of PB BLASTER and WD40 to no avail letting it soak for days. Any other way to get these off?
    Thanks
  2. jadnashua
    Got an impact wrench? I'm told that's how they're installed...with the age and corrosion, it may be the only way to remove them as well without twisting the plumbing into a pretzel.
  4. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    I get a good quality six sided socket 1" drive and a long breaker to get the leverage needed.
    [​IMG]
  5. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    sometimes they dont come out
    they can be hell to get out and on occasoin they wont come out....
    you might need someone to hold the heater in place while you try to turn out that bolt... or the heater will move
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I take them out with 1 hand and no need to hold the tank with my battery powered Milwaulkee Impact gun...
    [​IMG]
  7. SewerRatz
    Nov 20, 2008
    Chicago, IL
    Aw man now I need to get me one of them.
  8. Redwood
    Dec 15, 2007
    Service Plumber
    Good for changing tires too.:D
  9. hj
    caveat
    Just beware that if the tank is marginal, you can break the welds when you create the force necessary to remove them. Also, the curved dip tube ONLY keeps the tank clean when there is enough velocity to do so. Most new faucets with their limited flow will not do it. The bathtub and clothes washer are usually the only things that make it work these days. AND, the stuff it stirs up does not "disappear". It has to go someplace and that someplace is usually the aerators of the faucets, plugging them up.
Similar Threads: Can't remove
Water Heater Forum, Tanks Anode Rod Aluminum broken in two; can't get rod out of tank! Feb 11, 2017
Water Heater Forum, Tanks Can't light Rheem 22V40FN Nov 29, 2016
Water Heater Forum, Tanks HELP: Can't get 1" stainless flex connectors to seal to inlet/outlet nipples Dec 31, 2015
Water Heater Forum, Tanks Water heater circuit breaker turned self off, can't be turned on Oct 27, 2014
Water Heater Forum, Tanks How to remove Whirpool hot water traps May 6, 2013
