Can''t get Pump Down to Mate with Pitless
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Eldonw, Sep 23, 2013.
  1. Eldonw
    Eldonw New Member
    Sep 20, 2013
    Indiana
    I have a Wieses pitless adapter.
    I have lowered the pump down the well. It hands up just before or right at where the adapter should be.
    The first time I needed it to go down 4 more inches and it would have been in place. I pulled it up to look at it and make sure that the lever was all the way down. Now it is hanging up a little further away.
    I am so close but so far! lol
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Are you sure the pump isn't hitting the bottom of the well?
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    +1
    That would be my guess. Keep in mind that if the motor gets buried in sediment that it can lose needed cooling flow. Is the well top or bottom fed?
  5. Eldonw
    Eldonw New Member
    Sep 20, 2013
    Indiana
    I did wonder that but it is the exact same length as before. I am replacing a bad pump.
    I do not know if the well is top or bottom fed sorry. How do you tell?
  6. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    How deep is the pump set? How far down does the casing go? Is is screened? Is it a rock bore?
    The answers to those questions may indicate whether or not it is top fed.
  7. Eldonw
    Eldonw New Member
    Sep 20, 2013
    Indiana
    The pump is 65 ft. I do not know about the casing. I will have to figure out what the other things mean.
  8. valveman
    Mar 15, 2006
    Lubbock, Texas
    It is not uncommon for you to have pulled the old pump out of 3 or 4 inches of sand, and now the new pump won't go back to the same depth. You can usually even see the line on the old motor where the sand had filled up to.
  9. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Been there, done that. Twice I shortened the drop pipe to get by until I could get the sand blown out of the well.
  10. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Did the motor quit of did the wet end wear out from the sand? If the motor died from lack of cooling, consider putting a sleeve on the new pump after you get the well cleaned out.
  11. Eldonw
    Eldonw New Member
    Sep 20, 2013
    Indiana
    I do not know. It has rained here so I can not see anything on the pump that would tell me about the sand.
    How do you clean the well out?
  12. Eldonw
    Eldonw New Member
    Sep 20, 2013
    Indiana
    The pipe is schedule 80 I think. If I need to shorten it how should I do that? It is threaded and screws into the adapter.
  13. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    The DIY way is to rent a large compressor and shove the air line down the well. When you turn the air on, it will blow a lot of mud and water up into the air and onto everything nearby.
    My well guy did it with a tanker truckload of water and a 2" fire pump.
    A decade later, I did it the poorboy way when I could not get the well guy to come out. I made up an auger on the end of 60 feet of pipe and ran it down and tripped it back out several times. Then I put my old pump down the hole and pumped the mud until it ran clear. Got back 15 feet of casing that way.
Similar Threads: Can''t Pump
Pumps and Tanks Well Forum & Blog. Water is life. "Porky" masterpumpman Yesterday at 2:48 PM
Pumps and Tanks Well Forum & Blog. Water is life. Cycle an idle well pump Yesterday at 8:57 AM
Pumps and Tanks Well Forum & Blog. Water is life. Water Not Flowing Into House, Is It The Pump? Friday at 6:21 PM
Pumps and Tanks Well Forum & Blog. Water is life. Flat or twisted cable for deep well pump Thursday at 8:25 AM
Pumps and Tanks Well Forum & Blog. Water is life. Well pump replacement and bad advice Tuesday at 4:05 PM
