Can't get knobs of stems. Any ideas?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by TigerDriver, Dec 10, 2007.
  1. TigerDriver
    TigerDriver New Member
    Jul 5, 2005
    Retired
    Salem, VA
    I need to fix a faucet drips in my shower/tub. I assumed that these faucets take standard neoprene washers.
    I removed the screw from each knob, but I can't for the life of me get them off the stems. I've wiggled them; I've tried heating them with a hair dryer; I've even tried to pry them off with a couple of small wrecking bars (I stopped prying when I thought I was in danger of cracking a tile).
    Is there something special about these fixtures (click here for photo)? Any suggestions about how to get the knobs off.
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Buy a handle puller for $10.00 at the hardware store. They'll come off in ten seconds.
    While you're at it buy some plumbing sockets for those stems.
  4. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    There's also some magical loosener-upper called PB Blaster or something like that that's been highly recommended for situations like this. Available in any auto parts outlet. Works.
  5. Verdeboy
    Jun 12, 2006
    I'm not sure that this is the right application for PB Blaster, since the handle puller is made exclusively to pull handles. And it works everytime.
    The PB Blaster may or may not loosen them up. But it will definitely stink up the bathroom.:eek:
  6. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    I agree he needs the puller, but I squirt some of this stuff on stuck parts whether or not I've got fancy tools. Smells even better than WD-40 in the morning...
  7. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    MMMMM
    I would give it a good spray. I had a handle puller break.
  8. Verdeboy
    Jun 12, 2006
    You guys must have a rare sense of smell. I've had customers complain to me for a week after I sprayed that stuff indoors.
    BTW, was it a "good" handle puller that broke or a cheapie?
  9. TigerDriver
    Jul 5, 2005
    Retired
    Salem, VA
    Bought both puller and sockets. Like you said, the puller yanked 'em off in seconds, and the sockets made quick work of extracting the stems.
    Thanks for fast/good advice.
  10. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    They were the same as in that pic. Then again I bought them at the HomeCheapo, so not good by default.
  11. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    They make good ones?
  12. Verdeboy
    Jun 12, 2006
    I think the best is the "Big Yank Senior." I think the major difference is the center rod that goes through the screw hole. If that rod is too thin, it will bend.
    Of course, if the handle is really fused on, there's always the tried and true method of using a channel locks to snap off the handle with the top part of the stem.
  13. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    I wish they'd make one with real tool steel so the angled grabbers don't bend on a hard-to-remove handle. I've got one that's essentially a sliding hammer, like a body repairman's puller, and that's good for yanking the faucet loose in the wall.
    I've got a couple of relatively new ones, and one came with a ferrule puller, which was a good bonus since my tool box with the ferrule puller had been stolen.
    And you don't have to break the end off the stem - you can drill out the center. Your way may be faster, though.
  14. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    [​IMG]
    I've had much good luck with this...always use Free-All lubricant minutes before to help release the splines from the pot metal handles. I always put plumber's grease on the splines/holding screw in any rebuild.
  15. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    I do the same. It is best to think of the next time.
  16. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Of course nobody suggested a seat wrench set to pull out the old corroded seats that chewed up the washer... Next time soon!
  17. Verdeboy
    Jun 12, 2006
    I'm sure you know that washers don't always get chewed up. They usually just get flattened down to the point where they start to leak.
    Just figured, he was spending enough money as it was. If it still leaked after rebuilding/replacing the valve stems, I would've had him buy a set of seat wrenches.
Similar Threads: Can't knobs
Plumbing Forum, Professional & DIY Advice Kitchen faucet removal. Can't get nut off. Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Can't figure out where smell is coming from in bathroom Jan 13, 2017
Plumbing Forum, Professional & DIY Advice Can't find this sink clip Nov 7, 2016
Plumbing Forum, Professional & DIY Advice Can't figure out knocking pipes... Oct 31, 2016
Plumbing Forum, Professional & DIY Advice Can't figure out what this sound is. Help? Aug 26, 2016
