can't get drain out for new garbage disposal
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tim123, Jul 2, 2013.
  1. tim123
    tim123 New Member
    Jul 2, 2013
    Florida
    Hi. I'm trying to install a new garbage disposal.
    I took the old one out (Kitchenaid) but I can't get the rest of the drain out because this ring is stuck (shown in pic).
    Any tricks to getting this thing off. I don't think it's threaded.
    I also can't figure a way to retrofit the new Badger to the existing drain. The existing is too big.
    Any help appreciated.
    Thanks
  2. hj
    IT is probably installed with silicone caulking. Hit the bottom of it with a hammer and drive it up out of the sink opening.
  4. tim123
    tim123 New Member
    Jul 2, 2013
    Florida
    Thanks hj. There are notches in the ring that need to line up with the nubs on the drain part so it will pass over the nubs.
    I'm all for hammers and duck tape and gittin er done, just worried about bending the sink hole....
  5. jadnashua
    Your picture is out of focus, so it's hard to say, but it does look like there's a bead of silicon there. If so, it may be a real bear getting it out of there without damaging the sink. THen, to get a good seal, you have to scrape off all of the old caulk and silicon is a pain, especially when laying on your back underneath the sink! Personally, I'd leave it there and install a replacement from the ISE line (they make them for other companies, so there are multiple brands that fit exactly the same). Some steel wool on the inside of the drain from the top and it should look like new. The ISE Evolution series is very quiet and has a decent warranty.
  6. tim123
    tim123 New Member
    Jul 2, 2013
    Florida
    Thanks Jim. Looking at the pic I can see how you guys think there is silicone. But, I'm pretty sure there is no sealant of any kind (except for rust).
  7. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
    Have you tried twisting the chrome part hanging down with a big pair of channel locks or a pipe wrench? You might have to tear it up to get it out.
  8. Hairyhosebib
    Hairyhosebib New Member
    Jun 23, 2010
    Arizona
    Looks like silicone to me too. Do you have a sawzall? A good minute is all you would need. I would not pound on it with a hammer.
  9. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    A strap wrench would help to rotate it and break it free.
    A Large Oil Filter wrench may work, If you do not have a strap wrench.
    Good Luck.
  10. hj
    once you loosen it with the hammer, it will rotate to line up with the notches.
  11. tim123
    tim123 New Member
    Jul 2, 2013
    Florida
    Thanks for the replies guys.
    Gonna go get some PB Blaster and a new sawzall blade. I just don't know where to cut it where the blade will bite.
    (and, maybe a bigger hammer)
    Anyway, that is last resort I think.
  12. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    That is a better Picture.
    I think you may find that it unscrews.
    Good Luck.
  13. John28
    John28 Member
    Mar 17, 2013
    PA
    Isn't it just a back-up ring with a rubber gasket above? If that's the case I'd pry between the ring and gasket with a stiff puddy knife or screwdriver tip to break free, then rotate once loose, might be corroded to drain?
  14. John28
    John28 Member
    Mar 17, 2013
    PA
    Is it off yet?
  15. tim123
    tim123 New Member
    Jul 2, 2013
    Florida
    Couldn't get it off.
    Tried all the suggestions but got nowhere.
    finally took a sawzall to the drain hoping to cut some notches so the drain would squeeze smaller or somethin.
    nicked the sink. woops.
    I'm watching Craigslist for a new sink..
    I didn't mention that I am in the middle of a kitchen remodel, which makes this a particular pain in the ass as I will have to replace the sink again whenever I get around to the new counter (undermount).
    c'est la vie.
  16. John28
    John28 Member
    Mar 17, 2013
    PA
    When I originally read sawzall, I saw a new sink coming.
  17. hj
    That was also my first thought when he said "saw" of any kind. He took a fairly easy job and turned it into a project.
  18. Terry
    Aug 17, 2004
    Just so more people know, the old fashioned hack saw will work in many cases. It does less damage.
    A flat blade screw driver and a hammer may have worked to spin the flat part around too. Just tap, tap, tap and around it goes.
    Also, no Tape on those sink connections. Water supplies come "with" rubber cone washers. All the tape does is get between that seal, and make the threads harder to run down and make tight.
    I know the flunky at the home center likes to sell tape, but it's almost never, ever needed.
    A big part of my job is taking everything apart, removing all the tape and putting it back together clean.
    [​IMG]
  19. tim123
    tim123 New Member
    Jul 2, 2013
    Florida
    Yea, tap tap tap didn't work. The pieces were fused by rust.
    Thanks for the tape info...
  20. hj
    tap, tap, tap, is what a shoemaker does. You needed to bang, bang, bang. So far, I have never had to cut a disposer mount loose.
  21. Terry
    Aug 17, 2004
    hj, most plumbers have pliers with them, which they can use to pry off the plate.
    A homeowner often does't have what I call normal tools.
    I can't think of any plumber taking more than a few seconds to pull that plate off.
Similar Threads: can't drain
Plumbing Forum, Professional & DIY Advice can't remove tub overflow drain Jun 13, 2015
Plumbing Forum, Professional & DIY Advice Why can't I temporarily block this drain? Dec 15, 2014
Plumbing Forum, Professional & DIY Advice Can't remove Tub/Shower Drain piece! Tried pliers but looking for tool or ideas... Oct 1, 2012
Plumbing Forum, Professional & DIY Advice Can't get bath sink drain flange to seal Aug 31, 2011
Plumbing Forum, Professional & DIY Advice kitchen sink drain basket....can't find the right one. HELP!! Jan 26, 2010
