Cant fit in 60" Tub
Discussion in 'Shower & Bathtub Forum & Blog' started by larman, Oct 13, 2012.
  1. larman
    larman New Member
    Sep 2, 2011
    Long Island NY
    I am trying to install a 60" tub and there is barely enough room to fit it in. I have no room to maneuver it in the baseboard heat and finished tile is stopping me for laying it flat of the floor and installing it? Are there any tricks or suggestions on how to get this in?
  2. jadnashua
    Are the walls around the tub opening all bare to the studs? If not, you probably will not get it in with finished walls outside the area.
  4. Terry
    Aug 17, 2004
    If you only have a little space above the tub open, you won't able to "spin" the tub in. Most tubs are installed during the construction phase before the drywall is installed. When I replace a tub, it normally has the backer board removed first, then the tub is installed and new backer board installed last. Trying to install a tub with the tile in place is going to be a losing battle.
  5. plumbmingsanjose
    plumbmingsanjose New Member
    Oct 7, 2012
    India
    Hi,
    You need to remove the tile and backer. You should have 60" between the studs to wiggle it in.
Similar Threads: Cant
Shower & Bathtub Forum & Blog Cant get Kohler to change from bath to shower Apr 16, 2010
Shower & Bathtub Forum & Blog i cant get part of my shower diverter stem out Sep 2, 2009
Shower & Bathtub Forum & Blog cant remove cold valve Jan 17, 2009
Shower & Bathtub Forum & Blog Bath/shower faucet cant' be installed on centerline Oct 1, 2008
Shower & Bathtub Forum & Blog cant remove the mechanis for the tub drain!! HELP Sep 5, 2008
