Can't beat Leaks at Couplings
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by thumpngood, Feb 2, 2009.
  1. thumpngood
    thumpngood New Member
    Feb 2, 2009
    Hi,
    DIY'r here. I have a leak and tried 2 setups as indicated below, arrows show what I did in-line. I have this problem below a sink and shower faucet. All new hardware.
    CPVC to 1/2" CPVC male adapter >>Leak>> 1/2 - 3/8 Water Supply Valve>> 3/8 - 1/2 Flex Host >> Faucet
    Used Tephon tape at every coupling " >> ". In both cases the leak occurred between the adapter & the water supply 1/2 side of the water supply valve. I tried 2 and 3 layers of Teflon tape, light tightening, then very strong tightening.
    What's going on? After laying 20 feet of CPVC, and replacing drainage system for bathroom, I'd be :eek: embarrassed to call a plumber because I can't get what I thought would be straightforward fittings not to leak.
    - David
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Try these transition fittings...
    Plastic threads are oh so lame...
    [​IMG] [​IMG]
  4. thumpngood
    Feb 2, 2009
    Hey Redwood,
    I really appreciate your time. Hears what I've done... and what you suggest... just to be clear.
    Not sure why copper to (what ever the metal is that the valve is... steel with crome?) wouldn't work.
    Thanks,
    - David[​IMG]
  5. Redwood
    Dec 15, 2007
    Service Plumber
    The top way in you picture is a guaranteed leak.
    The second and third one is slightly better but has an extra connection that could be a problem.
    The method I showed using the male transition fitting should work well I would wrap the male threads with teflon tape then use a teflon pipe dope such as magaloc over it. Kinda like a belt and suspenders approach.
  6. hj
    valves
    Most plumbers would have used compression valves rather than screwed ones and avoided the problem entirely.
  7. Cass
    Cass Plumber
    Nov 12, 2005
    If you have done this a few times the stop may have expanded and that may be causing the problem... not enough teflon tape...a fine crack in the stop...bad threads...not tight enough...try getting a new stop...personaly I use 4-5 wraps of teflon...
  8. thumpngood
    Feb 2, 2009
    Thanks
    Thanks again to all. going to try these responses in order of least cost, and hope to be rid of the leaks. Next I'll call a plumber.
Similar Threads: Can't beat
Plumbing Forum, Professional & DIY Advice Kitchen faucet removal. Can't get nut off. Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Can't figure out where smell is coming from in bathroom Jan 13, 2017
Plumbing Forum, Professional & DIY Advice Can't find this sink clip Nov 7, 2016
Plumbing Forum, Professional & DIY Advice Can't figure out knocking pipes... Oct 31, 2016
Plumbing Forum, Professional & DIY Advice Can't figure out what this sound is. Help? Aug 26, 2016
