Cannot unsweat brass/copper fitting
Discussion in 'Shower & Bathtub Forum & Blog' started by DIYMike, Feb 16, 2005.
  1. DIYMike
    DIYMike New Member
    Jan 30, 2005
    I'm trying to seperate the 1/2"copper tubing from my moen tub filler valve assembly. I was able to remove the copper from the brass "filler" tube, but cannot remove it from the brass "valve" tube. It looks like a sweat connection, it seems hot enough and touching solder to it melts instantly, but it is not loosening up. Are there "factory" welds, or do I need a different torch or something?
    Help, thanks!
    - Michael
  2. Clayton
    Clayton Plumber
    Sep 26, 2004
    hot hot hot
    Are you talking about a Moen roman tub faucet?
    If so, I believe they come from the factory with the short pieces of copper already installed in the sides and bottom of the valves. So the installer is to assemble them with a tee and short copper tube for the tub spout. Since this requires the installer to make sweat connections within 3"-5" of the factory connections I would imagine these factory connections are brazed or at least use a joining material that has a higher melting point than that of your standard solder. If you haven't ruined the joint, then I would just use sweat fittings to extend the nipples as you want them.
    Some of these faucets come completely assembled on 10" centers.
  4. DIYMike
    DIYMike New Member
    Jan 30, 2005
    yep - then I need to replace them :(
    Darn, I was fooled by the easy to remove filler connection. I not only cut them too short, but I'm sure I overheated them as well. So - are replacements going to cost as much as a whole new setup?
  5. DIYMike
    DIYMike New Member
    Jan 30, 2005
    Moen 4999
    Thanks for your help Clayton. You clued me in to the problem, and solution. The roughin for this unit is 4999... ~$70.
    Found them online, but hope to find one locally (North County San Diego).
Similar Threads: Cannot unsweat
Shower & Bathtub Forum & Blog Cannot find this tub drain Oct 19, 2016
Shower & Bathtub Forum & Blog Mixet, Cannot Identify Old Shower Faucet Jul 27, 2016
Shower & Bathtub Forum & Blog I cannot Match this fixture Apr 1, 2015
Shower & Bathtub Forum & Blog Cannot find bathtub leak. Please help! Apr 7, 2014
Shower & Bathtub Forum & Blog Please help,cannot take the handle off, no screws.see picture, Oct 11, 2013
