Cannot remove bathtub handles
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by quickstep, Mar 20, 2013.
  1. quickstep
    quickstep DIY Junior Member
    Nov 9, 2006
    Savoy, IL
    I have a leaking bathtub faucet and cannot remove the bathtub handles on older Eljer faucets. I have tried just about everything including a puller with no luck. Any ideas? Once I get the handles off what then?
  2. hj
    I have had a few faucets where I had to break the stems to remove the handles, and if the is the solution make sure you have replacement stems before you start. I have also had very few that did not remove with a puller so I would have to see what kind of puller you are using. Try screwing a "hollow head cap screw" into the stem and press the puller's pin against that. It is hardened so it will not bend and will give a better surface to press against. "What then"? You take the faucet apart and repair it.
Similar Threads: Cannot remove
Plumbing Forum, Professional & DIY Advice Cannot Remove Stuck Ceramic Cartridge Valve! Aug 26, 2016
Plumbing Forum, Professional & DIY Advice Cannot Remove Shower Handle After Removing Center Screw Jun 21, 2016
Plumbing Forum, Professional & DIY Advice Cannot remove Grohe single-lever faucet handle May 30, 2016
Plumbing Forum, Professional & DIY Advice Cannot remove handle Apr 1, 2014
Plumbing Forum, Professional & DIY Advice 1" Copper Union..Stuck Cannot Loosen to Remove? Jun 10, 2011
