Canadian dishwasher install...with a twist ;o)
Discussion in 'Canadian Plumbing Code Questions' started by bitsdoo, Aug 19, 2010.
  1. bitsdoo
    bitsdoo New Member
    Aug 19, 2010
    ON, Canada
    Alright, here goes. First things first I did a search and could not find my situation so I'm starting a new thread. Doing a kitchen reno and in that replaced the dishwasher (herein DW). To make things more accessible incase there is trouble down the road I want to change the plumbing. The old DW plumbing was typical, drain going to the sink plumbing and tied in with a DW tee. DW supply also came off the sink plumbing.
    Wher the DW will sit is directly above my furnace room, and the point of entry of all water and the main drain/stack. I want to plumb the supply from the basement (no problem here) and tie the DW drain in to the basement as well. I've included a diagram (which is attached) of what I want to do. I think I've included all pertinant info, if you need anything else just let me know. The house is a 4 level sidesplit, with the kitchen being directly above the lowest/basment floor. Obviously there is more plumbing but it is irrelevant (IMHO).
    Please provide feedback on this install, am I up to code? Do we see any issues with the plumbing and if so what do I need to change.The new plumbing is circled.
    Thanks in advance for all your help.
  2. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    BC
    Is that a trap after where the DW ties into the sink drain? You cannot install a trap in this way and if there is a trap for the kitchen sink you will siphon it when the dishwasher drains. Why are you doing this? The way it was is the standard and best way IMO to hook up a DW.
  4. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Well the fixture outlet coming off the kitchen sink is VERY GOOFY but not against code. However the running trap you have drawn in there is against code.
  5. bitsdoo
    bitsdoo New Member
    Aug 19, 2010
    ON, Canada
    Thanks for the replies gentlemen.
    First things first, drawing is revised to show vent and second trap, my fault for not takiing a better look. The picture now shows exactly what I have on the kitchen sink take off.
    Alright the only new install is the part circled in red (i.e. the DW install), everything else is existng and is what I walked into. I want to install the DW like this so that I can access the plumbing if I have to for a leak or issue. You see, on the new cabinetry that I'm installing will be a marble tile countertop. Once this counter top goes on it doesn't come off without breaking it. I want all plumbing to be easily accessible and the best way for me to do that is to have it all in the furnace room which is directly below the DW and the kitchen. I could run the DW drain to the kitchen sink if I need to, I'll just run it under the floor and then back up. Why is the trap aganst code? What do I need to do to make it within code?
    Jay.
  6. Jerome2877
    Aug 25, 2009
    BC
    So you won't be able to remove the DW without breaking the counter? Not the best plan but your call. Now that you have shown a vent it won't siphon the sink trap but you still have a running trap in that line. You would need to install a trap then Y it into the line.
  7. bitsdoo
    bitsdoo New Member
    Aug 19, 2010
    ON, Canada
    Thanks for the reply. I can remove the DW without breaking the counter, I won't be able to get to the plumbing\drain (which runs along the bottom and back of the cabinets hidden.
    Should I take out the running trap? I don't see a use for it if there is a trap on both the sink and the DW. Any rules/code I need to follow?
  8. Terry
    Aug 17, 2004
    Probably any thing goes in Canada.
    Here is how I would do it South of the border in the US.
    [​IMG]
  9. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    ...ouch! That's not very nice.
  10. Terry
    Aug 17, 2004
    Where is the vent for the basement shower?
    Oh yeah, Can a da.
    And take out the running trap and install a trap above the floor that's vented for the dishwasher.
    I love what this guy writes Here is a nice link to Bert Polk's plumbing tips
  11. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    How many feet will the DW drain hose travel if it goes back to the sink connection?
    answer this first bitsdoo.
    bitsdoo, you left things out : I'll bet there is a sink near the shower. The trap arm for the shower may be OK without a vent, if it is short enough and wet vented from the basement bathroom lav.
    i find it hard to believe the double trap is there.
  12. MikeON
    MikeON New Member
    Apr 17, 2013
    gueph, Ontario
    We do the same thing here in Ontario, Canada except the air gap. Here, DW hose goes up as high as possible before connecting to GD.
  13. hj
    No "competent" plumber would have installed the drain line the way you show it. You do not have a trap for the dishwasher drain, and may be showing it connected directly to the drain riser. This appears to be a case of someone thinking, "anyone can be a plumber. All it takes is some pipe and a lot of fittings as long as it angles downward".
Similar Threads: Canadian dishwasher
Canadian Plumbing Code Questions Clarification of Manitoba/Canadian plumbing codes Nov 15, 2012
Canadian Plumbing Code Questions anyone have an extra copy of the 2010 canadian plumbing code? Jun 6, 2012
Canadian Plumbing Code Questions Canadian Code FAQs Jul 17, 2010
Canadian Plumbing Code Questions Dishwasher direct drain to basement and main soil stack Sep 18, 2015
