Can you use a 277V switch on a 120V circuit?
Discussion in 'Electrical Forum discussion & Blog' started by philefriendly, Oct 13, 2010.
  1. philefriendly
    philefriendly New Member
    Aug 14, 2006
    Seattle, WA
    Hi-
    I happen to have an occupancy sensor/dimmer switch that is rated for 277V, and I'd like to use it for a light on a regular 120V circuit. Would this work? I'm skeptical because the switch (Wattstopper WD-180) only says it is rated at 277V, whereas they do have other models that are rated 120V-277V.
    Thanks in advance!
  2. jadnashua
    Probably not since it is electronic. Maybe, you'd have to call them to be sure, or read the installation manual, if available on-line, to find out. Non-electronic stuff like simple switches, wires, connectors, etc. that are rated for (maybe much) higher voltages than planned, are fine to use on a lower voltage. Electronic stuff may or may not work at a lower voltage.
  4. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    Since it is rated at 277, it requires that voltage to operate.
    As you have found out, they make a 120/277 rated sensor, and that would work.
  5. jimbo
    jimbo Plumber
    The WD-170 is the 120 volt model.
  6. hj
    A simple on/off mechanical switch would be rated for its maximum voltage, but one with an electronic function will only work at the specified voltage.
  7. jadnashua
    Most electronic stuff is marked with a voltage range, if it can work with various inputs. When it is listed with one voltage, generally, that's it.
Similar Threads: 277V switch
Electrical Forum discussion & Blog Activating Pump via low voltage switch input Feb 11, 2017
Electrical Forum discussion & Blog 4 way switch multiple lights Feb 8, 2017
Electrical Forum discussion & Blog Strange Dimmer Switch Wiring Jan 6, 2017
Electrical Forum discussion & Blog One switch, two circuits. Possible? Dec 14, 2016
Electrical Forum discussion & Blog Light switch with pilot Nov 25, 2016
