can you solder copper and brass
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Don Juan, Oct 2, 2005.
  1. Don Juan
    Don Juan New Member
    Oct 2, 2005
    Hi,
    can you guys tell or spossible to solder copper with brass with torch (led)?
    thank you
  2. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    Short answer-Yes!
    Brass-an alloy consisting essentially of copper and zinc in variable proportions.
    Many solder fittings, especially for DWV are available in brass. Because brass and copper have different heating characteristics (brass takes longer to reach a particular temperature), care should be taken in making sure that no holidays are apparent in the solder flow.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    If you're soldering a brass valve to copper pipe, open the valve first. If using propane (most likely) it will take a bit longer to get the brass hot enough than if using Mapp gas. As stated, brass and copper will solder nicely.
Similar Threads: solder copper
Plumbing Forum, Professional & DIY Advice Help soldering a split copper fitting Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Solder fitting for 1/4" O.D copper tubing? Dec 15, 2014
Plumbing Forum, Professional & DIY Advice Copper Plumbing, Corroded from Water/Age or Sloppy Soldering and not wiping flux? Mar 3, 2014
Plumbing Forum, Professional & DIY Advice What's the most reliable way to go from copper to pex without soldering? Apr 15, 2013
Plumbing Forum, Professional & DIY Advice Copper to pex without soldering? Mar 21, 2013
